[gdal-dev] Get area of use of a spatial reference system
Even Rouault
even.rouault at spatialys.com
Tue Nov 27 09:02:38 PST 2018
On mardi 27 novembre 2018 16:53:10 CET Marcel Wendler wrote:
> Hi all,
> I am wondering if GDAL has a method that returns the area of use/the areas
> epsg code of a particular spatial reference system.
Marcel,
No, this is not currently imported from the EPSG dataset in the .csv files
used by GDAL. As part of my ongoing work on the SRS front in GDAL/PROJ, this
should be available in the GDAL version that will be out around May next year
(see my previous message)
Even
http://www.spatialys.com
