[gdal-dev] Translate leaves additional PAM .aux.xml file
Even Rouault even.rouault at spatialys.com
Fri Oct 5 08:22:24 PDT 2018
On vendredi 5 octobre 2018 13:47:49 CEST Robert Coup wrote:
> Hi,
> Can you give a procedure to reproduce this ? I couldn't from a quick test.
> > Things tend to go to PAM a bit too easily.
> Source image is at
> https://www.dropbox.com/sh/y2z8s2101w3rrxo/AAAh21saJqzHU40sy7UGg9Ffa?dl=0 —
> seems like it's the .aux file that's leading to it.
> To reproduce: gdal_translate -of GTiff fa0-11.tif out.tif
> From 2.3 at 8bbc3a0c3c
Fixed per
https://github.com/OSGeo/gdal/commit/24638830292ceae1017dbd9fef207111ca34fab4
http://www.spatialys.com
