[gdal-dev] WCS: Bug in WCSDataset110::GetCoverageRequest()
Odd Ragnar Lydersen
Odd-Ragnar.Lydersen at powel.no
Wed Oct 10 04:11:21 PDT 2018
I have investigated some more now, and I've found that the problem is perhaps the way I'm using the data source/service description file.
Here is what I do:
1) I open the wcs by providing the coverage I want by using describecoverage in the url:
std::string wcsDescribeCoverage = "WCS:https://wms.geonorge.no/skwms1/wcs.hoyde-dtm1_32?SERVICE=WCS&REQUEST=DescribeCoverage&IDENTIFIERS=1&VERSION=1.1.1";
GDALDatasetUniquePtr poDS1(GDALDataset::Open(wcsGetCapabilites.c_str(), GDAL_OF_READONLY, pOptionDriverName, pOptionOpenOptions, nullptr));
Now I have a valid data set, poDS1.
And a service description file has been created in the cache:
<WCS_GDAL>
<ServiceURL>https://wms.geonorge.no/skwms1/wcs.hoyde-dtm1_32?</ServiceURL>
<Version>1.1.1</Version>
<CoverageName>1</CoverageName>
<Parameters>SERVICE=WCS&REQUEST=DescribeCoverage</Parameters>
<TIMEOUT>300</TIMEOUT>
</WCS_GDAL>
2) Then I run GDALTranslate(), with a valid argList
GDALTranslateOptions *TranslateOptions = GDALTranslateOptionsNew(argList, NULL);
GDALDatasetH hOutputDataset = GDALTranslate("./test.xyz", GDALDataset::ToHandle(poDS2.get()), TranslateOptions, NULL);
During the GDALTranslate() I find that in wcsdataset110.cpp, WCSDataset110::GetCoverageRequest(), line 227:
- After the GetCoverage request have been constructed, the parameters from the service description file is used to overwrite the created request, making it a DescribeCoverage request as stated in the file.
- And DescribeCoverage don't want IDENTIFIER=someId, but IDENTIFIERS=someId
Then, my question is, how am I supposed to do this, to make it right?
>Odd-Ragnar<
-----Original Message-----
From: Peter Baumann <p.baumann at jacobs-university.de>
Sent: tirsdag 9. oktober 2018 15:10
To: jratike80 <jukka.rahkonen at maanmittauslaitos.fi>; gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] WCS: Bug in WCSDataset110::GetCoverageRequest()
On 09.10.2018 15:06, jratike80 wrote:
> Odd Ragnar Lydersen wrote
>> I think there is a bug in WCSDataset110::GetCoverageRequest()
>> At line 178: "&VERSION=%s&REQUEST=GetCoverage&IDENTIFIER=%s"
>> Should be : "&VERSION=%s&REQUEST=GetCoverage&IDENTIFIERS=%s"
>> At least that fixes my problem, and I can get one step further in my
>> effort to use the wcs driver, using C++ API, on Windows.
>>> Odd-Ragnar<
> Hi,
> I believe that GDAL is right and the WCS server that you are using is wrong.
> By reading the standard
> https://portal.opengeospatial.org/files/07-067r5
> the name of the parameter in GetCoverage is "identifier". However, for
> making it a bit more complicated for the developers it is called
> "identifiers" in DescribeCoverage.
well, design by committee effect if you will: DescribeCoverage can have more than one parameters, so it was requested to change to plural in the course of the adoption discussions.
whatever way you do it, you will do it wrong ;-)
cheers,
Peter (WCS/CIS spec editor)
> "This single ―identifiers parameter shall correspond to the repeatable
> ―identifier parameter in the UML model."
> -Jukka Rahkonen-
> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Dr. Peter Baumann
- Professor of Computer Science, Jacobs University Bremen
www.faculty.jacobs-university.de/pbaumann
mail: p.baumann at jacobs-university.de
tel: +49-421-200-3178, fax: +49-421-200-493178
- Executive Director, rasdaman GmbH Bremen (HRB 26793)
www.rasdaman.com, mail: baumann at rasdaman.com
tel: 0800-rasdaman, fax: 0800-rasdafax, mobile: +49-173-5837882 "Si forte in alienas manus oberraverit hec peregrina epistola incertis ventis dimissa, sed Deo commendata, precamur ut ei reddatur cui soli destinata, nec preripiat quisquam non sibi parata." (mail disclaimer, AD 1083)
