[gdal-dev] Netcdf coordinates swapped
Even Rouault
even.rouault at spatialys.com
Fri Oct 12 04:16:09 PDT 2018
On vendredi 12 octobre 2018 11:36:53 CEST Andre Joost wrote:
> Dear list,
> can anybody give some insight on this netcdf file:
> https://github.com/Andre-J/testing/raw/master/3A-DAY.nc
> ncdump reports:
> netcdf \3a-day {
> dimensions:
> AD = 2 ;
> chn = 2 ;
> nlon = 1440 ;
> nlat = 536 ;
> and Panoply displays it fine, but gdal_translate swaps the coordinates,
> returning a 536x1440 raster.
Actually, letting aside the geographic semantics and only reasoning in term of
image/cube, this is a width=536xheight=1440 raster since the fastest varying
dimension is the last one in the following declaration, that is nlat
float precipRateNearSurfMean(AD, chn, nlon, nlat) ;
So if you want to present it with rows in GDAL raster = values at same
latitude, you would need to flip it diagonaly, which is generally inefficient
for large rasters since that goes against the natural data organization in the
file.
> Is there any NCO or GDAL option to sanitize the axes?
Can't say for NCO, but not in GDAL. Would require a specific development to
handle such dataset that doesn't follow the usual CF conventions.
You could possibly use numpy to do the matrix transposition.
Even
http://www.spatialys.com
