[gdal-dev] WCS: Bug in WCSDataset110::GetCoverageRequest()
Odd Ragnar Lydersen
Odd-Ragnar.Lydersen at powel.no
Mon Oct 15 23:08:49 PDT 2018
Thanks for the help.
It works like it's supposed to now.
If I use it for this other wcs though, I get an error:
- URL: "WCS:http://openwms.statkart.no/skwms1/wcs.dtm?VERSION=1.1.1&identifiers=land_utm33_10m"
- Error message: ERROR 1: msWCSGetCoverage(): WCS server error. A non-zero RESX/RESY or WIDTH/HEIGHT is required but neither was provided.
(If I use vesion 2.0.1 then it's fine)
Is it a server error?
Is there a way around it, by adding some extra parameters?
>Odd-Ragnar<
-----Original Message-----
Sent: onsdag 10. oktober 2018 15:02
To: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] WCS: Bug in WCSDataset110::GetCoverageRequest()
Hi Odd Ragnar,
Without going very deep into this, I would do (and tried)
gdalinfo "WCS:https://wms.geonorge.no/skwms1/wcs.hoyde-dtm1_32"
This tells me that the preferred version of the service is 2.0.1 and it serves coverage Coverage1. However, if I want to use service version 1.1.1, I do
gdalinfo
"WCS:https://wms.geonorge.no/skwms1/wcs.hoyde-dtm1_32?version=1.1.1"
This tells me that version is ok but now the coverage name is 1, so
gdalinfo
"WCS:https://wms.geonorge.no/skwms1/wcs.hoyde-dtm1_32?version=1.1.1&coverage=1"
tells me details about this coverage which seems to be huge. Now that is the src_dataset string to be used in gdal_translate.
Ari
Odd Ragnar Lydersen kirjoitti 10.10.2018 klo 14:11:
> I have investigated some more now, and I've found that the problem is perhaps the way I'm using the data source/service description file.
> Here is what I do:
> 1) I open the wcs by providing the coverage I want by using describecoverage in the url:
> std::string wcsDescribeCoverage =
> "WCS:https://wms.geonorge.no/skwms1/wcs.hoyde-dtm1_32?SERVICE=WCS&REQU
> EST=DescribeCoverage&IDENTIFIERS=1&VERSION=1.1.1";
> GDALDatasetUniquePtr
> poDS1(GDALDataset::Open(wcsGetCapabilites.c_str(), GDAL_OF_READONLY,
> pOptionDriverName, pOptionOpenOptions, nullptr));
> Now I have a valid data set, poDS1.
> And a service description file has been created in the cache:
> <WCS_GDAL>
> <ServiceURL>https://wms.geonorge.no/skwms1/wcs.hoyde-dtm1_32?</ServiceURL>
> <Version>1.1.1</Version>
> <CoverageName>1</CoverageName>
> <Parameters>SERVICE=WCS&REQUEST=DescribeCoverage</Parameters>
> <TIMEOUT>300</TIMEOUT>
> </WCS_GDAL>
> 2) Then I run GDALTranslate(), with a valid argList
> GDALTranslateOptions *TranslateOptions =
> GDALTranslateOptionsNew(argList, NULL); GDALDatasetH hOutputDataset =
> GDALTranslate("./test.xyz", GDALDataset::ToHandle(poDS2.get()),
> TranslateOptions, NULL);
> During the GDALTranslate() I find that in wcsdataset110.cpp, WCSDataset110::GetCoverageRequest(), line 227:
> - After the GetCoverage request have been constructed, the parameters from the service description file is used to overwrite the created request, making it a DescribeCoverage request as stated in the file.
> - And DescribeCoverage don't want IDENTIFIER=someId, but
> IDENTIFIERS=someId
> Then, my question is, how am I supposed to do this, to make it right?
>> Odd-Ragnar<
> From: Peter Baumann <p.baumann at jacobs-university.de>
> Sent: tirsdag 9. oktober 2018 15:10
> To: jratike80 <jukka.rahkonen at maanmittauslaitos.fi>;
> On 09.10.2018 15:06, jratike80 wrote:
>> Odd Ragnar Lydersen wrote
>>> I think there is a bug in WCSDataset110::GetCoverageRequest()
>>> At line 178: "&VERSION=%s&REQUEST=GetCoverage&IDENTIFIER=%s"
>>> Should be : "&VERSION=%s&REQUEST=GetCoverage&IDENTIFIERS=%s"
>>> At least that fixes my problem, and I can get one step further in my
>>> effort to use the wcs driver, using C++ API, on Windows.
>>>> Odd-Ragnar<
>> Hi,
>> I believe that GDAL is right and the WCS server that you are using is wrong.
>> By reading the standard
>> https://portal.opengeospatial.org/files/07-067r5
>> the name of the parameter in GetCoverage is "identifier". However,
>> for making it a bit more complicated for the developers it is called
>> "identifiers" in DescribeCoverage.
> well, design by committee effect if you will: DescribeCoverage can have more than one parameters, so it was requested to change to plural in the course of the adoption discussions.
> whatever way you do it, you will do it wrong ;-)
> cheers,
> Peter (WCS/CIS spec editor)
>> "This single ―identifiers parameter shall correspond to the
>> repeatable ―identifier parameter in the UML model."
>> -Jukka Rahkonen-
>> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
>> gdal-dev mailing list
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> Dr. Peter Baumann
> - Professor of Computer Science, Jacobs University Bremen
> www.faculty.jacobs-university.de/pbaumann
> mail: p.baumann at jacobs-university.de
> tel: +49-421-200-3178, fax: +49-421-200-493178
> - Executive Director, rasdaman GmbH Bremen (HRB 26793)
> www.rasdaman.com, mail: baumann at rasdaman.com
> tel: 0800-rasdaman, fax: 0800-rasdafax, mobile: +49-173-5837882
> "Si forte in alienas manus oberraverit hec peregrina epistola incertis
> ventis dimissa, sed Deo commendata, precamur ut ei reddatur cui soli
> destinata, nec preripiat quisquam non sibi parata." (mail disclaimer,
> AD 1083)
