[gdal-dev] Creating external overviews for JP2 files?
jratike80
jukka.rahkonen at maanmittauslaitos.fi
Thu Oct 18 06:43:55 PDT 2018
alpa wrote
> Thanks for your reply,
> My bad, probably copy-pasting mistake. I've re-run the commands:
> Just to be sure I exported the GDAL_SKIP env var as well:
> export GDAL_SKIP=JP2OpenJPEG
> gdalinfo --formats
> ERS -raster- (rw+v): ERMapper .ers Labelled
> JP2KAK -raster,vector- (rwv): JPEG-2000 (based on Kakadu *v7.10.4*)
> JPIPKAK -raster- (ro): JPIP (based on Kakadu)
> L1B -raster- (rovs): NOAA Polar Orbiter Level 1b Data Set
> (No JP2OpenJPEG, by the way, I am using Kakadu 7.10.4)
> Looks like gdal_translate is producing a 0-filled raster:
> gdal_translate -outsize 50% 50% -co TILED=YES -co COMPRESS=JPEG -co
> PHOTOMETRIC=YCBCR ./T34WEB_20181015T104021_TCI_10m.jp2
> ./T34WEB_20181015T104021_TCI_10m.jp2.ovr *--config GDAL_SKIP JP2OpenJPEG*
I used your command for one of our orthophoto .jp2 files with these drivers
gdalinfo --formats|find "JP2"
JP2ECW -raster,vector- (rov): ERDAS JPEG2000 (SDK 5.3)
JP2MrSID -raster- (rov): MrSID JPEG2000
JP2OpenJPEG -raster,vector- (rwv): JPEG-2000 driver based on OpenJPEG
library
The resulting half-dimensioned GeoTIFF is good with all drivers. Without
having a recent Kakadu driver available I fear that I can't test anything
more.
If your build suppors debug messages you can have a new try by adding
"--debug on" into your gdal_translate command.
-Jukka Rahkonen-
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
