[gdal-dev] CSV file extension
Andreas Oxenstierna
ao at t-kartor.se
Thu Oct 25 03:06:43 PDT 2018
Thanks - missed that documentation.
Stopped reading at "OGR only supports CSV files ending with the
extension ".csv"
-maybe the sentences should be reorganised to someting like:
OGR supports CSV files ending with the extension ".csv" or any other CSV
file with any file extension if defining the source as CSV:<filename>
> Andreas Oxenstierna wrote
>> Can ogr read a csv file with another extension, like txt ?
>> I do not suceed
> Hi,
> From the manual page https://www.gdal.org/drv_csv.html
> "While in theory .csv files could have any extension, in order to
> auto-recognise the format OGR only supports CSV files ending with the
> extension ".csv". The datasource name may be either a single CSV file or
> point to a directory. For a directory to be recognised as a .csv datasource
> at least half the files in the directory need to have the extension .csv.
> One layer (table) is produced from each .csv file accessed.
> Starting with GDAL 1.8.0, for files structured as CSV, but not ending with
> .CSV extension, the 'CSV:' prefix can be added before the filename to force
> loading by the CSV driver."
> Try ogrinfo CSV:my_text.txt
> -Jukka Rahkonen-
> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Best Regards
Andreas Oxenstierna
T-Kartor Geospatial AB
mobile: +46 733 206831
mailto: ao at t-kartor.se
http://www.t-kartor.com
