[gdal-dev] Refactoring the test suite with pytest
Even Rouault
even.rouault at spatialys.com
Fri Oct 26 04:11:16 PDT 2018
Craig,
I just gave a try to your branch. This is awesome work !! I'm excited by the
perspective of no longer having to write the "gdaltest.post_reason(), return 'fail'"
boilerplate.
There are just a few remaining failures that are due to conversion issues (for example in
autotest/utilities/test_gdalbuildvrt_check, a test_gdalbuildvrt_check() method
is just a helper method used by real steps, and not a test step itself), but
this is defintely on the right track.
Craig, I'll email you with the report failures that may trigger in drivers you
have not built-in support.
I got a segmentation fault right at the end of the run, after the final report,
presumably at process termination.
-- Docs: https://docs.pytest.org/en/latest/warnings.html
============================================================== 13 failed, 5342 passed, 437 skipped, 4 xfailed, 1 warnings, 2 error in 744.30 seconds ===============================================================
Erreur de segmentation (core dumped)
I ran pytest individually in each subdirectory, but couldn't reproduce that.
Will try again with core generation enabled
For those, we didn't try, an extract of the report:
./autotest$ pytest
=============================================================================================== test session starts ================================================================================================
platform linux2 -- Python 2.7.12, pytest-3.8.0, py-1.6.0, pluggy-0.7.1
rootdir: /home/even/gdal/git/gdal_pytest/autotest, inifile: pytest.ini
collected 5797 items
ogr/ogr_arcgen.py ...... [ 0%]
ogr/ogr_avc.py ..... [ 0%]
ogr/ogr_basic_test.py .........s......... [ 0%]
ogr/ogr_bna.py ....... [ 0%]
ogr/ogr_cad.py .......... [ 0%]
ogr/ogr_carto.py ...s [ 0%]
ogr/ogr_cloudant.py ...... [ 0%]
ogr/ogr_couchdb.py .... [ 1%]
ogr/ogr_csv.py .............................s......................... [ 2%]
ogr/ogr_db2.py ssssssss [ 2%]
ogr/ogr_db2_hack.py ... [ 2%]
ogr/ogr_dgn.py ........s. [ 2%]
ogr/ogr_dgnv8.py sssss. [ 2%]
ogr/ogr_dxf.py .......................................................
Even
http://www.spatialys.com
