[gdal-dev] Trouble with GPKG and colors
Even Rouault
even.rouault at spatialys.com
Mon Oct 29 05:29:43 PDT 2018
On lundi 29 octobre 2018 14:19:12 CET Ben Avrahami wrote:
> Hello, I'm trying to save a byte raster to a geopackage. I ran into a
> problem that the geopackage raster driver does not behave as expected when
> working with bytes and color tables. I have written a python script that
> explains the issue (attached):
> The script creates 4 rasters in similar ways but prints different outputs:
> GTIFF(no palette): Minimum=0, Maximum=9, Color Table=False, band count=1
> GTIFF(palette): Minimum=0, Maximum=9, Color Table=True, band count=1
> GPKG(no palette): Minimum=0, Maximum=9, Color Table=False, band count=4
> GPKG(palette): Minimum=0, Maximum=255, Color Table=False, band count=4
> The problem is that even though we set a color table in the geopackage when
> writing, it reads as having no color table when reading. Worse yet, the
> original raster values are lost when written with a color table.
> Is there any workaround or fix for this? We want to be able to keep
> non-image byte data with a palette to geopackage.
Change
ds = gdal.OpenEx(path, gdal.OF_READONLY)
to
ds = gdal.OpenEx(path, gdal.OF_READONLY, open_options=['BAND_COUNT=1'])
if you know that all the tiles have a color table. Note: that will not work if
your raster is made of a single tile that has some padding (which seems to be
the case in your demo code), because the driver has to expand to RGBA to be
able to fill transparent pixels.
The fact that you don't get excatly the characteristics of the input dataset
comes from the fact that GPKG can store tiles of different formats, band
count, etc, so the driver defaults to exposing at RGBA as a safe setting
http://www.spatialys.com
