[gdal-dev] C++ API for WCS: GetCapabilities and the new cache
Ari Jolma ari.jolma at gmail.com
Fri Sep 7 04:19:37 PDT 2018
Odd Ragnar Lydersen kirjoitti 07.09.2018 klo 12:57:
> Hi, I'm struggling to understand the new setup for WCS.
> In the documentation it says:
> - If the URL does not contain a coverage name, the driver attempts to fetch the capabilities document from the server, parse it, and show the resulting metadata to the user.
> How is this  done using the C++ API?
The "show the resulting metadata to the user" is assuming gdalinfo. If
you do for instance
gdalinfo
WCS:https://beta-karttakuva.maanmittauslaitos.fi/wcs/service/ows?version=2.0.1
,i.e., opening that URL with the WCS driver, the driver downloads the
capabilities XML into the cache (probably $HOME/.gdal/wcs_cache/),
parses it, and creates - into the cache - a PAMDataset metadata file.
The latter contains the coverages as subdatasets for example.
This is the same as calling GDALOpenEx with the URL. GDALOpenEx gives
you a GDALDataset object.
> - I would like to get the result from GetCapabilities listed, so that I can parse the result to establish what the coverage names are, for a given wcs.
The capabilities XML is in the cache but the driver has the code to
parse it and it has parsed it.
> Also from the documentation:
> - Note that when the "WCS:<URL>" syntax for dataset name is used, the contents of the service description file is meant to be modified by using options
> Are these options set by calling the GDALOpen function like, GDALOpen("wcs: UserPwd=myPwd; HttpAuth=BASIC; ...",  GA_ReadOnly)?
The options are in the OpenOptions parameter in GDALOpenEx.
Best,
Ari
>> Odd-Ragnar<
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
