[gdal-dev] Reading remote jp2k files
Even Rouault
even.rouault at spatialys.com
Fri Sep 7 06:39:49 PDT 2018
Victor,
> I'm a jp2000 noob but do you know if windowed reads of remote jp2 data could
> be optimized in some way? I am curious if we could see a "cloud optimized
> jpeg2000" someday?
There is the JPIP protocol that was designed for efficient streaming, but it
requires a dedicated server and client.
For a pure HTTP file-serving solution, there are different aspects
* For non-tiled JPEG2000, coefficients are spread a bit over the whole file,
so you may have to seek a lot to get them. I guess some progression orders
might be more favorable (namely PCRL: Position-component-resolution level-
layer) if you want to have efficient subwindowing, but that should be tested.
* For tiled JPEG2000, the above issue becomes less relevant, but the main
issue is to be able to efficiently locate a tile in the file. For that, the
optional TLM packet marker should be written in the JPEG2000 file
Those were theoretical concerns. Now on the practical side, some
implementations might be better than others in making an efficient use of file
optimizations. For non-tiled JPEG2000, OpenJPEG currently requires ingesting
the whole codestream in memory (even if since openjpeg 2.3 only a subpart of
it will be decompressed for windowed reads). And for tiled JPEG2000, it
ignores the TLM marker and browse through the tilepart headers to identify the
tiles. So work would be needed to improve that. From recollection, Kakadu does
a good job in those areas.
An alternative might be to store JPEG2000 blobs as the payload of a tiled
GeoTIFF. There are some software editors that do that, apparently in slightly
different ways (they might not always put a completely valid JPEG2000
codestream, not sure)
Even
http://www.spatialys.com
