[gdal-dev] Meaning of First pass in reading GeoJSON
Even Rouault
even.rouault at spatialys.com
Thu Sep 13 01:28:27 PDT 2018
On jeudi 13 septembre 2018 08:00:00 CEST Rahkonen Jukka (MML) wrote:
> Hi,
> What does GDAL do when it reads the whole GeoJSON file as "GeoJSON: First
> pass"? Could it make the total process faster if user could give the same
> information that is gathered with the First pass somehow directly, or is
> that step needed in any case?
The first pass does a full scan of the file to mostly detect the attribute
schema and the layer geometry type.
In theory it could be omitted if the user had a way to provide that
information, but that would mean a new format & code for that...
Even
http://www.spatialys.com
