[gdal-dev] Exception in GDALAllRegister()
FA
finn at arildsen.com
Fri Sep 14 07:56:24 PDT 2018
Hi Even,
Thanks for your kind response and information.
I'm sorry, I should have clarified that I'm using GDAL ver. 2.3.1. I have
used /MTd both in the test app and in nmake.opt when compiling GDAL.
Changing both to /MDd doesn't seem to make a difference - the same fatal
exception occurs.
The call stack looks like this:
> GDALTEST.exe!std::_Tree<std::_Tmap_traits<CPLStringT<void>,enum
CPLErr (__cdecl*)(void * *,int,void *,int,int,enum GDALDataType,enum
GDALDataType,int,int),std::less<CPLStringT<void>
>,std::allocator<std::pair<CPLStringT<void> const ,enum CPLErr
GDALDataType,int,int)> >,0> >::_Lbound<CPLStringT<void> >(const
CPLStringT<void> & _Keyval) Line 2046 C++
GDALDataType,int,int)> >,0> >::lower_bound(const CPLStringT<void> & _Keyval)
Line 1481 C++
GDALTEST.exe!std::map<CPLStringT<void>,enum CPLErr (__cdecl*)(void *
GDALDataType,int,int)> > >::_Try_emplace<CPLStringT<void>
>(CPLStringT<void> && _Keyval) Line 228 C++
GDALDataType,int,int)> > >::try_emplace<>(CPLStringT<void> && _Keyval) Line
263 C++
GDALDataType,int,int)> > >::operator[](CPLStringT<void> && _Keyval) Line 199
C++
GDALTEST.exe!GDALAddDerivedBandPixelFunc(const char * pszFuncName,
CPLErr(*)(void * *, int, void *, int, int, GDALDataType, GDALDataType, int,
int) pfnNewFunction) Line 1029 C++
GDALTEST.exe!GDALRegisterDefaultPixelFunc() Line 921 C++
GDALTEST.exe!GDALRegister_VRT() Line 379 C++
GDALTEST.exe!GDALAllRegister() Line 70 C++
I wonder if this rings a bell with you?
Thanks in advance.
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
