[gdal-dev] FileGDB and vsimem
Even Rouault even.rouault at spatialys.com
Fri Sep 14 12:02:19 PDT 2018
Tim,
You guessed right.
> Is there any way to write a geodatabase to a vsimem path,
No
> or is that
> something ESRI would have to change in their SDK?
Yes. There is no customizable file abstraction layer in the SDK.
On Linux, you could probably use a tmpfs mount as a workaround.
Even
http://www.spatialys.com
