[gdal-dev] Warping into gpkg PseudoTMS_GlobalMercator fails
Rahkonen Jukka (MML) jukka.rahkonen at maanmittauslaitos.fi
Wed Sep 19 00:55:51 PDT 2018
Even Rouault wrote
> On mercredi 19 septembre 2018 05:06:59 CEST Rahkonen Jukka (MML) wrote:
>> A workaround is to warp  into TIFF and run gdal_translate afterwards
>> gdal_translate -of gpkg -co tiling_scheme=PseudoTMS_GlobalMercator 3857.tif
>> 3857.gpkg
> That's definitely the recomended way. The CreateCopy() method then internally
> kind of sets-up gdalwarp with an appropriate resolution value.
I believe that you meant "sets-up gdal_translate with an appropriate resolution value" because
the previous gdalwarp command is totally unaware about what will happen next:
gdalwarp -of gtiff -t_srs epsg:3857 sfdem.tif 3857.tif
-Jukka-
