[gdal-dev] Fwd: Post for gdal-dev
Scott Arko
saarko at alaska.edu
Mon Sep 24 15:49:02 PDT 2018
Hello GDAL Devs,
We are trying to use /vsicurl to allow users to access data in our
datapool. However, we are having a problem that I'm hoping one of you may
know the answer to. Below is a summary from a developer on the team.
Is there a way to make vsicurl persist cookies across redirects?
I'm trying to use vsicurl to interact with a URL behind OAuth
authentication. The OAuth behavior involves redirects, cookies, and .netrc
credentials. This curl command will successfully download the file
(assumes credentials are in a .netrc file):
curl --remote-name --location --netrc --cookie-jar ""
https://grfn.asf.alaska.edu/door/download/S1-IFG_RM_M1S2_TN143_20180924T122701-20180918T122541_s1-resorb-686f-v1.2.1-standard.zip
But an equivalent vsicurl command fails:
gdalinfo --config CPL_CURL_VERBOSE YES --config CPL_VSIL_CURL_USE_HEAD NO
"/vsizip/vsicurl/
I'm effectively missing the --cookie-jar behavior. In the attached output,
curl receives a session cookie on line 167, and forwards it with the
subsequent redirect on line 182 as desired. vsicurl receives the same
cookie on line 96, but does not forward it with the subsequent redirect on
line 106. This leads to an infinite redirect loop, and vsicurl eventually
fails with a "Maximum (10) redirects followed" error.
Scott Arko
Alaska Satellite Facility Deputy Director
University of Alaska Fairbanks
903 Koyukuk Drive
Fairbanks, AK 99775
Phone: (907) 474 - 5570
email: saarko at alaska.edu
http://www.asf.alaska.edu
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180924/f4e658da/attachment-0001.html>
$ curl --verbose --remote-name --location --netrc --cookie-jar "" https://grfn.asf.alaska.edu/door/download/S1-IFG_RM_M1S2_TN143_20180924T122701-20180918T122541_s1-resorb-686f-v1.2.1-standard.zip
* Couldn't find host grfn.asf.alaska.edu in the .netrc file; using defaults
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0* Trying 35.169.212.126...
* TCP_NODELAY set
* Connected to grfn.asf.alaska.edu (35.169.212.126) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* Cipher selection: ALL:!EXPORT:!EXPORT40:!EXPORT56:!aNULL:!LOW:!RC4:@STRENGTH
* successfully set certificate verify locations:
* CAfile: /etc/pki/tls/certs/ca-bundle.crt
CApath: none
* TLSv1.2 (OUT), TLS header, Certificate Status (22):
} [5 bytes data]
* TLSv1.2 (OUT), TLS handshake, Client hello (1):
} [512 bytes data]
* TLSv1.2 (IN), TLS handshake, Server hello (2):
{ [98 bytes data]
* TLSv1.2 (IN), TLS handshake, Certificate (11):
{ [5720 bytes data]
* TLSv1.2 (IN), TLS handshake, Server key exchange (12):
{ [333 bytes data]
* TLSv1.2 (IN), TLS handshake, Server finished (14):
{ [4 bytes data]
* TLSv1.2 (OUT), TLS handshake, Client key exchange (16):
} [70 bytes data]
* TLSv1.2 (OUT), TLS change cipher, Client hello (1):
} [1 bytes data]
* TLSv1.2 (OUT), TLS handshake, Finished (20):
} [16 bytes data]
* TLSv1.2 (IN), TLS change cipher, Client hello (1):
{ [1 bytes data]
* TLSv1.2 (IN), TLS handshake, Finished (20):
{ [16 bytes data]
* SSL connection using TLSv1.2 / ECDHE-RSA-AES128-GCM-SHA256
* ALPN, server accepted to use h2
* Server certificate:
* subject: C=US; postalCode=99775; ST=AK; L=Fairbanks; street=910 Yukon Drive; O=University of Alaska System; OU=Alaska Satellite Facility; CN=*.asf.alaska.edu
* start date: Apr 25 00:00:00 2018 GMT
* expire date: Apr 25 23:59:59 2019 GMT
* subjectAltName: host "grfn.asf.alaska.edu" matched cert's "*.asf.alaska.edu"
* issuer: C=US; ST=MI; L=Ann Arbor; O=Internet2; OU=InCommon; CN=InCommon RSA Server CA
* SSL certificate verify ok.
* Using HTTP2, server supports multi-use
* Connection state changed (HTTP/2 confirmed)
* Copying HTTP/2 data in stream buffer to connection buffer after upgrade: len=0
} [5 bytes data]
* Using Stream ID: 1 (easy handle 0x178de60)
} [5 bytes data]
> GET /door/download/S1-IFG_RM_M1S2_TN143_20180924T122701-20180918T122541_s1-resorb-686f-v1.2.1-standard.zip HTTP/2
> Host: grfn.asf.alaska.edu
> User-Agent: curl/7.55.1
> Accept: */*
{ [5 bytes data]
* Connection state changed (MAX_CONCURRENT_STREAMS updated)!
} [5 bytes data]
< HTTP/2 302
< date: Mon, 24 Sep 2018 22:13:31 GMT
< content-type: text/html; charset=iso-8859-1
< content-length: 551
< location: https://urs.earthdata.nasa.gov/oauth/authorize?app_type=401&client_id=iwntGSgHy9yoog7Mjag0dQ&response_type=code&redirect_uri=https%3A%2F%2Fgrfn.asf.alaska.edu%2Fdoor%2Foauth&state=aHR0cDovL2dyZm4uYXNmLmFsYXNrYS5lZHUvZG9vci9kb3dubG9hZC9TMS1JRkdfUk1fTTFTMl9UTjE0M18yMDE4MDkyNFQxMjI3MDEtMjAxODA5MThUMTIyNTQxX3MxLXJlc29yYi02ODZmLXYxLjIuMS1zdGFuZGFyZC56aXA
< server: Apache/2.4.18 (Ubuntu) OpenSSL/1.0.2g mod_wsgi/4.3.0 Python/2.7.12
* Ignoring the response-body
{ [551 bytes data]
100 551 100 551 0 0 551 0 0:00:01 --:--:-- 0:00:01 3826
* Connection #0 to host grfn.asf.alaska.edu left intact
* Issue another request to this URL: 'https://urs.earthdata.nasa.gov/oauth/authorize?app_type=401&client_id=iwntGSgHy9yoog7Mjag0dQ&response_type=code&redirect_uri=https%3A%2F%2Fgrfn.asf.alaska.edu%2Fdoor%2Foauth&state=aHR0cDovL2dyZm4uYXNmLmFsYXNrYS5lZHUvZG9vci9kb3dubG9hZC9TMS1JRkdfUk1fTTFTMl9UTjE0M18yMDE4MDkyNFQxMjI3MDEtMjAxODA5MThUMTIyNTQxX3MxLXJlc29yYi02ODZmLXYxLjIuMS1zdGFuZGFyZC56aXA'
* Trying 198.118.243.33...
* TCP_NODELAY set
* Connected to urs.earthdata.nasa.gov (198.118.243.33) port 443 (#1)
* ALPN, offering h2
CApath: none
} [5 bytes data]
} [512 bytes data]
{ [87 bytes data]
{ [4621 bytes data]
{ [333 bytes data]
{ [4 bytes data]
} [70 bytes data]
} [1 bytes data]
} [16 bytes data]
{ [1 bytes data]
{ [16 bytes data]
* ALPN, server did not agree to a protocol
* subject: C=US; ST=Maryland; L=Greenbelt; jurisdictionC=US; O=NASA (National Aeronautics and Space Administration); businessCategory=Government Entity; serialNumber=1958-07-29; CN=urs.earthdata.nasa.gov
* start date: Sep 12 12:29:03 2017 GMT
* expire date: Sep 12 12:59:01 2019 GMT
* subjectAltName: host "urs.earthdata.nasa.gov" matched cert's "urs.earthdata.nasa.gov"
* issuer: C=US; O=Entrust, Inc.; OU=See www.entrust.net/legal-terms; OU=(c) 2014 Entrust, Inc. - for authorized use only; CN=Entrust Certification Authority - L1M
* Server auth using Basic with user 'asjohnston'
} [5 bytes data]
> GET /oauth/authorize?app_type=401&client_id=iwntGSgHy9yoog7Mjag0dQ&response_type=code&redirect_uri=https%3A%2F%2Fgrfn.asf.alaska.edu%2Fdoor%2Foauth&state=aHR0cDovL2dyZm4uYXNmLmFsYXNrYS5lZHUvZG9vci9kb3dubG9hZC9TMS1JRkdfUk1fTTFTMl9UTjE0M18yMDE4MDkyNFQxMjI3MDEtMjAxODA5MThUMTIyNTQxX3MxLXJlc29yYi02ODZmLXYxLjIuMS1zdGFuZGFyZC56aXA HTTP/1.1
> Host: urs.earthdata.nasa.gov
> Authorization: Basic ********************************************
> Accept: */*
{ [5 bytes data]
< HTTP/1.1 302 Found
< Server: nginx/1.10.2
< Date: Mon, 24 Sep 2018 22:13:32 GMT
< Content-Type: text/html; charset=utf-8
< Transfer-Encoding: chunked
< Connection: keep-alive
< X-Frame-Options: SAMEORIGIN
< X-XSS-Protection: 1; mode=block
< X-Content-Type-Options: nosniff
< Access-Control-Allow-Origin: null
< Access-Control-Allow-Credentials: true
< Access-Control-Allow-Methods: GET, POST
< Access-Control-Expose-Headers: true
< Location: https://grfn.asf.alaska.edu/door/oauth?code=01d3cdf63e1d50b3ed30d1537455ad28c53e5c69dfbfd5734758328e5dcdd2e3&state=aHR0cDovL2dyZm4uYXNmLmFsYXNrYS5lZHUvZG9vci9kb3dubG9hZC9TMS1JRkdfUk1fTTFTMl9UTjE0M18yMDE4MDkyNFQxMjI3MDEtMjAxODA5MThUMTIyNTQxX3MxLXJlc29yYi02ODZmLXYxLjIuMS1zdGFuZGFyZC56aXA
< Cache-Control: no-cache
* Added cookie urs_user_already_logged="yes" for domain earthdata.nasa.gov, path /, expire 1537913612
< Set-Cookie: urs_user_already_logged=yes; domain=earthdata.nasa.gov; path=/; expires=Tue, 25 Sep 2018 22:13:32 GMT
* Added cookie _urs-gui_session="djEyNzFRVW9ha0VqVUhCV1hkakJUUlB0L2hDUXhaTHUzdmRlUU5KSGh1YklXMWkvMFNQNENySXorOWV1aU5Bak4vanZFN3lFb3dneDlJZkxrWGRRZk5BUUdxYUIyZkxudUpRcXR5WkIxTlFtUnpUVzRSZWN5MDJsWXlmNlBPU3F3cjhFRTJjTW5MSlRzaVZXWk9kMWVXd0hMK0lEcllPM1ZNWVR0VjZzQkQwPS0tNW1IaFFKM2hwTlJJcGxMRCtoQ20rUT09--1bb5fd391448b23ce39d72f23e9b3bc43b8777b0" for domain urs.earthdata.nasa.gov, path /, expire 1537913612
< Set-Cookie: _urs-gui_session=djEyNzFRVW9ha0VqVUhCV1hkakJUUlB0L2hDUXhaTHUzdmRlUU5KSGh1YklXMWkvMFNQNENySXorOWV1aU5Bak4vanZFN3lFb3dneDlJZkxrWGRRZk5BUUdxYUIyZkxudUpRcXR5WkIxTlFtUnpUVzRSZWN5MDJsWXlmNlBPU3F3cjhFRTJjTW5MSlRzaVZXWk9kMWVXd0hMK0lEcllPM1ZNWVR0VjZzQkQwPS0tNW1IaFFKM2hwTlJJcGxMRCtoQ20rUT09--1bb5fd391448b23ce39d72f23e9b3bc43b8777b0; path=/; expires=Tue, 25 Sep 2018 22:13:32 GMT; HttpOnly
< X-Request-Id: c37a5726-95a6-4ca4-9a68-a7bf76fcae51
< X-Runtime: 0.140991
< Strict-Transport-Security: max-age=31536000
{ [363 bytes data]
100 356 0 356 0 0 356 0 --:--:-- --:--:-- --:--:-- 0
* Connection #1 to host urs.earthdata.nasa.gov left intact
* Issue another request to this URL: 'https://grfn.asf.alaska.edu/door/oauth?code=01d3cdf63e1d50b3ed30d1537455ad28c53e5c69dfbfd5734758328e5dcdd2e3&state=aHR0cDovL2dyZm4uYXNmLmFsYXNrYS5lZHUvZG9vci9kb3dubG9hZC9TMS1JRkdfUk1fTTFTMl9UTjE0M18yMDE4MDkyNFQxMjI3MDEtMjAxODA5MThUMTIyNTQxX3MxLXJlc29yYi02ODZmLXYxLjIuMS1zdGFuZGFyZC56aXA'
* Found bundle for host grfn.asf.alaska.edu: 0x1772e30 [can multiplex]
* Re-using existing connection! (#0) with host grfn.asf.alaska.edu
* Using Stream ID: 3 (easy handle 0x178de60)
} [5 bytes data]
> GET /door/oauth?code=01d3cdf63e1d50b3ed30d1537455ad28c53e5c69dfbfd5734758328e5dcdd2e3&state=aHR0cDovL2dyZm4uYXNmLmFsYXNrYS5lZHUvZG9vci9kb3dubG9hZC9TMS1JRkdfUk1fTTFTMl9UTjE0M18yMDE4MDkyNFQxMjI3MDEtMjAxODA5MThUMTIyNTQxX3MxLXJlc29yYi02ODZmLXYxLjIuMS1zdGFuZGFyZC56aXA HTTP/2
> Accept: */*
{ [5 bytes data]
< HTTP/2 302
< date: Mon, 24 Sep 2018 22:13:32 GMT
< content-length: 312
< location: http://grfn.asf.alaska.edu/door/download/S1-IFG_RM_M1S2_TN143_20180924T122701-20180918T122541_s1-resorb-686f-v1.2.1-standard.zip
* Added cookie GRFNDoor="ba169b82-2872-4199-8249-8fd529335b82" for domain grfn.asf.alaska.edu, path /, expire 0
< set-cookie: GRFNDoor=ba169b82-2872-4199-8249-8fd529335b82; Path=/
{ [312 bytes data]
100 312 100 312 0 0 312 0 0:00:01 --:--:-- 0:00:01 312
* Issue another request to this URL: 'http://grfn.asf.alaska.edu/door/download/S1-IFG_RM_M1S2_TN143_20180924T122701-20180918T122541_s1-resorb-686f-v1.2.1-standard.zip'
* Trying 34.203.94.240...
* TCP_NODELAY set
* Connected to grfn.asf.alaska.edu (34.203.94.240) port 80 (#2)
> GET /door/download/S1-IFG_RM_M1S2_TN143_20180924T122701-20180918T122541_s1-resorb-686f-v1.2.1-standard.zip HTTP/1.1
> Accept: */*
> Cookie: GRFNDoor=ba169b82-2872-4199-8249-8fd529335b82
< HTTP/1.1 301 Moved Permanently
< Content-Type: text/html; charset=iso-8859-1
< Content-Length: 337
< Server: Apache/2.4.18 (Ubuntu) OpenSSL/1.0.2g mod_wsgi/4.3.0 Python/2.7.12
< Location: https://grfn.asf.alaska.edu/door/download/S1-IFG_RM_M1S2_TN143_20180924T122701-20180918T122541_s1-resorb-686f-v1.2.1-standard.zip
{ [337 bytes data]
100 337 100 337 0 0 337 0 0:00:01 0:00:01 --:--:-- 337
* Connection #2 to host grfn.asf.alaska.edu left intact
* Issue another request to this URL: 'https://grfn.asf.alaska.edu/door/download/S1-IFG_RM_M1S2_TN143_20180924T122701-20180918T122541_s1-resorb-686f-v1.2.1-standard.zip'
* Using Stream ID: 5 (easy handle 0x178de60)
} [5 bytes data]
> Accept: */*
{ [5 bytes data]
< HTTP/2 302
< date: Mon, 24 Sep 2018 22:13:33 GMT
< content-type: text/html; charset=utf-8
< content-length: 2435
< location: https://gsfc-ngap-asf-grfn-private-prod.s3.amazonaws.com/S1-IFG_RM_M1S2_TN143_20180924T122701-20180918T122541_s1-resorb-686f-v1.2.1-standard.zip?AWSAccessKeyId=ASIAV5PGEDVWQYUGWJGS&Expires=1537827228&x-amz-security-token=FQoGZXIvYXdzEDMaDLnS7iHpMhor1S3LyyKiBKU9f%2FdBchtWDUq0YzLxE3V6lQpcNNYvlI0dQXJiDD485Cf1ogF0hwinItfOb%2BxarLu7KHn0a%2BYgRLwKqIw%2Fx4iT6hiW10FmIPSar7QUTEQyOHGq9DJr%2BDWUzYwLoRFae8ojwr141oGF5kQhmGejoeGlATT4aC6KI6VdH7b%2FL34Z0vFxGLtFyeZeH8IhU36jGmi8Ef8XpPQNp3Im4nvq8Np7J8BVVwnpUceVdHOytrPrsNhCEWdnAhwooPyMGTKt2bSERQRhAiMslWQqV6cUgTfeZIH61odOBzdz6rhdKHZOgiDqSHkptScu5fO1XvVno3rqY0WjQvL4vTtDtFjGhPCtCkfgodfDuMdFITCa2UpinUVh6LFdv1F%2BUx64UELal4w%2Fe17uNRbOQ65WeSQIUaXKh7%2F50PEKrLJfpPOzUtDIa%2BcYdmLOzvdBbFUjsPjFB2YKrHJ5kh0P%2FxWCJNd9bSdHdpu7uNitgv8nKk%2B9AAUMTy5PdL5RWuxapVPhv58QDRZHUAMu10DbP7ucJrRaNbD5%2BTN%2Bd5elMuL3SZewcQYx97rWXgY9mX8lqpJoANzxCmYuL67545SLpmNPw5kfDTXUMHYKL3XIHm6HYECKZ5o7Zk5r5RDzv0NOpugl8Fk9fsYTA%2B7e9bicLub3Wu4S%2FRxV7aRc85C6fdaJiSKOLtlnIHZdYrcJcK5CDLF%2Bt9nnXxWBWzRo%2Bk3KYBQ0XmADBUBjgyifs6TdBQ%3D%3D&Signature=M43caFk%2Fp381Wkfevkee0bgGRVU%3D&userid=asjohnston
{ [2435 bytes data]
100 2435 100 2435 0 0 2435 0 0:00:01 0:00:01 --:--:-- 0
* Issue another request to this URL: 'https://gsfc-ngap-asf-grfn-private-prod.s3.amazonaws.com/S1-IFG_RM_M1S2_TN143_20180924T122701-20180918T122541_s1-resorb-686f-v1.2.1-standard.zip?AWSAccessKeyId=ASIAV5PGEDVWQYUGWJGS&Expires=1537827228&x-amz-security-token=FQoGZXIvYXdzEDMaDLnS7iHpMhor1S3LyyKiBKU9f%2FdBchtWDUq0YzLxE3V6lQpcNNYvlI0dQXJiDD485Cf1ogF0hwinItfOb%2BxarLu7KHn0a%2BYgRLwKqIw%2Fx4iT6hiW10FmIPSar7QUTEQyOHGq9DJr%2BDWUzYwLoRFae8ojwr141oGF5kQhmGejoeGlATT4aC6KI6VdH7b%2FL34Z0vFxGLtFyeZeH8IhU36jGmi8Ef8XpPQNp3Im4nvq8Np7J8BVVwnpUceVdHOytrPrsNhCEWdnAhwooPyMGTKt2bSERQRhAiMslWQqV6cUgTfeZIH61odOBzdz6rhdKHZOgiDqSHkptScu5fO1XvVno3rqY0WjQvL4vTtDtFjGhPCtCkfgodfDuMdFITCa2UpinUVh6LFdv1F%2BUx64UELal4w%2Fe17uNRbOQ65WeSQIUaXKh7%2F50PEKrLJfpPOzUtDIa%2BcYdmLOzvdBbFUjsPjFB2YKrHJ5kh0P%2FxWCJNd9bSdHdpu7uNitgv8nKk%2B9AAUMTy5PdL5RWuxapVPhv58QDRZHUAMu10DbP7ucJrRaNbD5%2BTN%2Bd5elMuL3SZewcQYx97rWXgY9mX8lqpJoANzxCmYuL67545SLpmNPw5kfDTXUMHYKL3XIHm6HYECKZ5o7Zk5r5RDzv0NOpugl8Fk9fsYTA%2B7e9bicLub3Wu4S%2FRxV7aRc85C6fdaJiSKOLtlnIHZdYrcJcK5CDLF%2Bt9nnXxWBWzRo%2Bk3KYBQ0XmADBUBjgyifs6TdBQ%3D%3D&Signature=M43caFk%2Fp381Wkfevkee0bgGRVU%3D&userid=asjohnston'
* Couldn't find host gsfc-ngap-asf-grfn-private-prod.s3.amazonaws.com in the .netrc file; using defaults
* Trying 52.216.86.83...
* TCP_NODELAY set
* Connected to gsfc-ngap-asf-grfn-private-prod.s3.amazonaws.com (52.216.86.83) port 443 (#3)
* ALPN, offering h2
CApath: none
} [5 bytes data]
} [512 bytes data]
{ [87 bytes data]
{ [2514 bytes data]
{ [333 bytes data]
{ [4 bytes data]
} [70 bytes data]
} [1 bytes data]
} [16 bytes data]
{ [1 bytes data]
{ [16 bytes data]
* subject: C=US; ST=Washington; L=Seattle; O=Amazon.com Inc.; CN=*.s3.amazonaws.com
* start date: Sep 22 00:00:00 2017 GMT
* expire date: Jan 3 12:00:00 2019 GMT
* subjectAltName: host "gsfc-ngap-asf-grfn-private-prod.s3.amazonaws.com" matched cert's "*.s3.amazonaws.com"
* issuer: C=US; O=DigiCert Inc; OU=www.digicert.com; CN=DigiCert Baltimore CA-2 G2
} [5 bytes data]
> GET /S1-IFG_RM_M1S2_TN143_20180924T122701-20180918T122541_s1-resorb-686f-v1.2.1-standard.zip?AWSAccessKeyId=ASIAV5PGEDVWQYUGWJGS&Expires=1537827228&x-amz-security-token=FQoGZXIvYXdzEDMaDLnS7iHpMhor1S3LyyKiBKU9f%2FdBchtWDUq0YzLxE3V6lQpcNNYvlI0dQXJiDD485Cf1ogF0hwinItfOb%2BxarLu7KHn0a%2BYgRLwKqIw%2Fx4iT6hiW10FmIPSar7QUTEQyOHGq9DJr%2BDWUzYwLoRFae8ojwr141oGF5kQhmGejoeGlATT4aC6KI6VdH7b%2FL34Z0vFxGLtFyeZeH8IhU36jGmi8Ef8XpPQNp3Im4nvq8Np7J8BVVwnpUceVdHOytrPrsNhCEWdnAhwooPyMGTKt2bSERQRhAiMslWQqV6cUgTfeZIH61odOBzdz6rhdKHZOgiDqSHkptScu5fO1XvVno3rqY0WjQvL4vTtDtFjGhPCtCkfgodfDuMdFITCa2UpinUVh6LFdv1F%2BUx64UELal4w%2Fe17uNRbOQ65WeSQIUaXKh7%2F50PEKrLJfpPOzUtDIa%2BcYdmLOzvdBbFUjsPjFB2YKrHJ5kh0P%2FxWCJNd9bSdHdpu7uNitgv8nKk%2B9AAUMTy5PdL5RWuxapVPhv58QDRZHUAMu10DbP7ucJrRaNbD5%2BTN%2Bd5elMuL3SZewcQYx97rWXgY9mX8lqpJoANzxCmYuL67545SLpmNPw5kfDTXUMHYKL3XIHm6HYECKZ5o7Zk5r5RDzv0NOpugl8Fk9fsYTA%2B7e9bicLub3Wu4S%2FRxV7aRc85C6fdaJiSKOLtlnIHZdYrcJcK5CDLF%2Bt9nnXxWBWzRo%2Bk3KYBQ0XmADBUBjgyifs6TdBQ%3D%3D&Signature=M43caFk%2Fp381Wkfevkee0bgGRVU%3D&userid=asjohnston HTTP/1.1
> Host: gsfc-ngap-asf-grfn-private-prod.s3.amazonaws.com
> Accept: */*
{ [5 bytes data]
< HTTP/1.1 200 OK
< x-amz-id-2: ubW6hUXtkY8A1+abtzglWomJHZ+oGx50gs9TqcfUO4ZrxjBtJ87p09Sq5IhHCIPB0xesy4VTwCw=
< x-amz-request-id: 436A4AC682C1E286
< Date: Mon, 24 Sep 2018 22:13:34 GMT
< Last-Modified: Mon, 24 Sep 2018 18:29:39 GMT
< ETag: "190bf52e5c82147e454335b326d4f1f4-7"
< Accept-Ranges: bytes
< Content-Type: application/zip
< Content-Length: 431359485
< Server: AmazonS3
{ [5 bytes data]
100 411M 100 411M 0 0 68.5M 0 0:00:06 0:00:06 --:--:-- 87.7M
* Connection #3 to host gsfc-ngap-asf-grfn-private-prod.s3.amazonaws.com left intact
* WARNING: failed to save cookies in
$ gdalinfo --config CPL_CURL_VERBOSE YES --config CPL_VSIL_CURL_USE_HEAD NO "/vsizip/vsicurl/https://grfn.asf.alaska.edu/door/download/S1-IFG_RM_M1S2_TN143_20180924T122701-20180918T122541_s1-resorb-686f-v1.2.1-standard.zip"
* TCP_NODELAY set
* Connected to grfn.asf.alaska.edu (34.203.94.240) port 443 (#0)
CApath: none
* ALPN, server accepted to use http/1.1
Accept: */*
< Date: Mon, 24 Sep 2018 22:14:48 GMT
< Content-Length: 551
< Location: https://urs.earthdata.nasa.gov/oauth/authorize?app_type=401&client_id=iwntGSgHy9yoog7Mjag0dQ&response_type=code&redirect_uri=https%3A%2F%2Fgrfn.asf.alaska.edu%2Fdoor%2Foauth&state=aHR0cDovL2dyZm4uYXNmLmFsYXNrYS5lZHUvZG9vci9kb3dubG9hZC9TMS1JRkdfUk1fTTFTMl9UTjE0M18yMDE4MDkyNFQxMjI3MDEtMjAxODA5MThUMTIyNTQxX3MxLXJlc29yYi02ODZmLXYxLjIuMS1zdGFuZGFyZC56aXA
* TCP_NODELAY set
CApath: none
Accept: */*
< Location: https://grfn.asf.alaska.edu/door/oauth?code=ed859c566e4a840188f0d0e0d5c56e8d393518afb5afc80054a5058bdeede42f&state=aHR0cDovL2dyZm4uYXNmLmFsYXNrYS5lZHUvZG9vci9kb3dubG9hZC9TMS1JRkdfUk1fTTFTMl9UTjE0M18yMDE4MDkyNFQxMjI3MDEtMjAxODA5MThUMTIyNTQxX3MxLXJlc29yYi02ODZmLXYxLjIuMS1zdGFuZGFyZC56aXA
< Set-Cookie: urs_user_already_logged=yes; domain=earthdata.nasa.gov; path=/; expires=Tue, 25 Sep 2018 22:14:48 GMT
< Set-Cookie: _urs-gui_session=U2hoWnJhRitIMXhnSEk5MXZqSFVhUHJCaGJLWGN5dk9INlhSZkkrTllKRHFBOHVTbU1mbUxuTUZMU2JTc1N6R0JJTHZ0ek5lK3NXVEZyVVZFcXZzNzl2dEJaZTVZZlMvMlRVMzhLQVNZMkdRQThlZmNHVkdPbmtOMW5Bb3JsdmkvdEpFeXpCRktHbXlIZHUwMW5XOVhUOHQzb3dhNUJjYXB6eWFLUW1KTm5ZPS0tVlV0dmhwSzJHQXZnSUd0WUI5NE5NZz09--26ad2d27d0299a00c73817b1694348f29d511600; path=/; expires=Tue, 25 Sep 2018 22:14:48 GMT; HttpOnly
< X-Request-Id: 80c96dd7-1757-4b9e-a065-97828e9f9ad5
< X-Runtime: 0.179878
* Issue another request to this URL: 'https://grfn.asf.alaska.edu/door/oauth?code=ed859c566e4a840188f0d0e0d5c56e8d393518afb5afc80054a5058bdeede42f&state=aHR0cDovL2dyZm4uYXNmLmFsYXNrYS5lZHUvZG9vci9kb3dubG9hZC9TMS1JRkdfUk1fTTFTMl9UTjE0M18yMDE4MDkyNFQxMjI3MDEtMjAxODA5MThUMTIyNTQxX3MxLXJlc29yYi02ODZmLXYxLjIuMS1zdGFuZGFyZC56aXA'
* Found bundle for host grfn.asf.alaska.edu: 0x22b6bd0 [can pipeline]
> GET /door/oauth?code=ed859c566e4a840188f0d0e0d5c56e8d393518afb5afc80054a5058bdeede42f&state=aHR0cDovL2dyZm4uYXNmLmFsYXNrYS5lZHUvZG9vci9kb3dubG9hZC9TMS1JRkdfUk1fTTFTMl9UTjE0M18yMDE4MDkyNFQxMjI3MDEtMjAxODA5MThUMTIyNTQxX3MxLXJlc29yYi02ODZmLXYxLjIuMS1zdGFuZGFyZC56aXA HTTP/1.1
Accept: */*
< Date: Mon, 24 Sep 2018 22:14:49 GMT
< Content-Length: 312
< Set-Cookie: GRFNDoor=6db6a08e-facd-4b62-a556-4354b670e81b; Path=/
< Location: http://grfn.asf.alaska.edu/door/download/S1-IFG_RM_M1S2_TN143_20180924T122701-20180918T122541_s1-resorb-686f-v1.2.1-standard.zip
* TCP_NODELAY set
* Connected to grfn.asf.alaska.edu (35.169.212.126) port 80 (#2)
Accept: */*
Accept: */*
* Found bundle for host urs.earthdata.nasa.gov: 0x23f3110 [can pipeline]
* Re-using existing connection! (#1) with host urs.earthdata.nasa.gov
Accept: */*
< Location: https://grfn.asf.alaska.edu/door/oauth?code=7afe6ad7bacd07f41b88846c7da343f0bc2ae4fc6919798e64d8432f9fdb74f9&state=aHR0cDovL2dyZm4uYXNmLmFsYXNrYS5lZHUvZG9vci9kb3dubG9hZC9TMS1JRkdfUk1fTTFTMl9UTjE0M18yMDE4MDkyNFQxMjI3MDEtMjAxODA5MThUMTIyNTQxX3MxLXJlc29yYi02ODZmLXYxLjIuMS1zdGFuZGFyZC56aXA
< Set-Cookie: urs_user_already_logged=yes; domain=earthdata.nasa.gov; path=/; expires=Tue, 25 Sep 2018 22:14:49 GMT
< Set-Cookie: _urs-gui_session=VVhoYlZHODVsVUZtbllCKzA0RFpyYjQweExRaU5va0ZGbHBhRTNpajhqWVV2UEhBOGxmWC8zTDBVaHhWUmlnSkd0T2cxNll4RXNpekxKSzBrYyszYmNpVU43dDBDcG5VbysvU3RBMmlEdWIrOWhzQmNnOXpacmFTaHVHZUlJc0pMcWdtRDhNRlBneHdXTjFJby95ZzlYdnZmdURJbG93MDJHM1EwL3UyNkFjPS0tU1VraEpoazkwQWdGSXVYbHh3d1EvQT09--6278ff15b1ea23a876b1eeff4404329b381aef22; path=/; expires=Tue, 25 Sep 2018 22:14:49 GMT; HttpOnly
< X-Request-Id: 8b35f84f-dc8e-458e-b1b1-059b25fc6783
< X-Runtime: 0.254830
* Issue another request to this URL: 'https://grfn.asf.alaska.edu/door/oauth?code=7afe6ad7bacd07f41b88846c7da343f0bc2ae4fc6919798e64d8432f9fdb74f9&state=aHR0cDovL2dyZm4uYXNmLmFsYXNrYS5lZHUvZG9vci9kb3dubG9hZC9TMS1JRkdfUk1fTTFTMl9UTjE0M18yMDE4MDkyNFQxMjI3MDEtMjAxODA5MThUMTIyNTQxX3MxLXJlc29yYi02ODZmLXYxLjIuMS1zdGFuZGFyZC56aXA'
> GET /door/oauth?code=7afe6ad7bacd07f41b88846c7da343f0bc2ae4fc6919798e64d8432f9fdb74f9&state=aHR0cDovL2dyZm4uYXNmLmFsYXNrYS5lZHUvZG9vci9kb3dubG9hZC9TMS1JRkdfUk1fTTFTMl9UTjE0M18yMDE4MDkyNFQxMjI3MDEtMjAxODA5MThUMTIyNTQxX3MxLXJlc29yYi02ODZmLXYxLjIuMS1zdGFuZGFyZC56aXA HTTP/1.1
Accept: */*
< Set-Cookie: GRFNDoor=1c8cb502-de20-48fb-99ec-dac6647235a9; Path=/
* Found bundle for host grfn.asf.alaska.edu: 0x24f37b0 [can pipeline]
* Re-using existing connection! (#2) with host grfn.asf.alaska.edu
Accept: */*
Accept: */*
Accept: */*
< Date: Mon, 24 Sep 2018 22:14:50 GMT
< Location: https://grfn.asf.alaska.edu/door/oauth?code=4a6fcae8bfa8a2f82c3650964d368c009880cec58a5825bff5325e26b8489d13&state=aHR0cDovL2dyZm4uYXNmLmFsYXNrYS5lZHUvZG9vci9kb3dubG9hZC9TMS1JRkdfUk1fTTFTMl9UTjE0M18yMDE4MDkyNFQxMjI3MDEtMjAxODA5MThUMTIyNTQxX3MxLXJlc29yYi02ODZmLXYxLjIuMS1zdGFuZGFyZC56aXA
< Set-Cookie: urs_user_already_logged=yes; domain=earthdata.nasa.gov; path=/; expires=Tue, 25 Sep 2018 22:14:50 GMT
< Set-Cookie: _urs-gui_session=cStzSHM5QmpvLzg2RS8rSnM4ZkpaMmVQdVY2NjQzV1VnU1o4djNIczNTQWVhS3ZiRks2K1F6ZytYaG43a1RMcHMzVEFaQjN1TE5iRXA1dGFLeDNhWC82ZUM1TnNNNXpWNVl3dWdjTUQ3b3VtSmlIZE5LTWhXMTJuWVBDaXFNT005MWtFVzQxR3U4M0VJWGNEeWFyTk5pbVZ5YllpQlVDNFNuTFI5YVRrajBZPS0tY1BuRU9SNllZN2E0TUV4SXlROTlOUT09--f440650bd6885b12ebce5ffee4b60b5b1003e307; path=/; expires=Tue, 25 Sep 2018 22:14:50 GMT; HttpOnly
< X-Request-Id: f5be8a9f-9863-48e4-8ff2-974c62997b1e
< X-Runtime: 0.167661
* Issue another request to this URL: 'https://grfn.asf.alaska.edu/door/oauth?code=4a6fcae8bfa8a2f82c3650964d368c009880cec58a5825bff5325e26b8489d13&state=aHR0cDovL2dyZm4uYXNmLmFsYXNrYS5lZHUvZG9vci9kb3dubG9hZC9TMS1JRkdfUk1fTTFTMl9UTjE0M18yMDE4MDkyNFQxMjI3MDEtMjAxODA5MThUMTIyNTQxX3MxLXJlc29yYi02ODZmLXYxLjIuMS1zdGFuZGFyZC56aXA'
> GET /door/oauth?code=4a6fcae8bfa8a2f82c3650964d368c009880cec58a5825bff5325e26b8489d13&state=aHR0cDovL2dyZm4uYXNmLmFsYXNrYS5lZHUvZG9vci9kb3dubG9hZC9TMS1JRkdfUk1fTTFTMl9UTjE0M18yMDE4MDkyNFQxMjI3MDEtMjAxODA5MThUMTIyNTQxX3MxLXJlc29yYi02ODZmLXYxLjIuMS1zdGFuZGFyZC56aXA HTTP/1.1
Accept: */*
< Set-Cookie: GRFNDoor=1807636b-3f69-4333-a108-ae4e76da1f2a; Path=/
* Maximum (10) redirects followed
ERROR 4: `/vsizip/vsicurl/https://grfn.asf.alaska.edu/door/download/S1-IFG_RM_M1S2_TN143_20180924T122701-20180918T122541_s1-resorb-686f-v1.2.1-standard.zip' does not exist in the file system,
and is not recognised as a supported dataset name.
gdalinfo failed - unable to open '/vsizip/vsicurl/https://grfn.asf.alaska.edu/door/download/S1-IFG_RM_M1S2_TN143_20180924T122701-20180918T122541_s1-resorb-686f-v1.2.1-standard.zip'.
