[gdal-dev] problem with a geotiff
mauge.philippe at free.fr mauge.philippe at free.fr
Tue Sep 25 09:59:54 PDT 2018
Please, I'd like to submit you an isssue about a geotiff file.
Go to the web site http://www.digitalglobe.com/resources/product-samples/tripoli-lybya
Choose to download the second file: System-Ready (1B), 50 cm
Unzip it and try to load the file 16MAR08101212-P1BS-055675519010_01_P001.TIF in GDAL
I can't load it in GDAL because no projection is returned by the fonction GetProjectionRef()
It can be loaded only if you create manually a .prj and a .tfw file.
The file is OK because it is correctly loaded in Global Mapper.
Usually I can load geotiff files in GDAL, but this file won't.
Can you try to load it and may be tell me what's wrong with it ?
Best regards
Philippe
L'absence de virus dans ce courrier électronique a été vérifiée par le logiciel antivirus Avast.
https://www.avast.com/antivirus
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180925/2f2fe2e9/attachment.html>
