Hello! Is it possible to create mpabox vector tiles for postgis data using c# SWIG bindings? Input: conn string, geometry select queery command text, bbox, custom tile size, custom tile grid Output: mvt pbf byte array. Thank you very much! -- Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
