[gdal-dev] How to run autotest
Fengting Chen fengting.chen at oracle.com
Tue Apr 9 08:33:19 PDT 2019
gdalinfo and gdal_translate are working fine. just pytest failed with
the same error.
Here is my configure:
./configure --prefix=${PREFIX} \
   --without-libtool \
   --disable-rpath \
   --with-libz=internal \
   --with-png=internal \
   --with-libtiff=internal \
   --with-geotiff=internal \
   --with-jpeg=internal \
   --with-gif=internal \
   --without-pg \
   --without-sqlite3 \
   --without-expat \
   --without-odbc \
   --with-curl=/usr/bin/curl-config \
   --without-perl \
   --without-pcre \
   --with-hdfs=no \
   --with-python=/scratch/SDK/Python-2.7.5/dist/bin/python \
   --with-proj=/scratch/SDK/proj-6.0.0/dist
After that:
make clean
make -j8 -s
cd apps; make -s test_ogrsf; cd ..
-Fengting
On 4/9/2019 4:22 AM, Even Rouault wrote:
> On lundi 8 avril 2019 17:20:45 CEST Fengting Chen wrote:
>> I rebuilt GDAl with python bindings without errors. Now I got a
>> different error:
>> ImportError while loading conftest
>> '/scratch/gdal/gdal/autotest/conftest.py'.
>> /home/fechen/.local/lib/python2.7/site-packages/six.py:709: in exec_
>>       exec("""exec _code_ in _globs_, _locs_""")
>> conftest.py:9: in <module>
>>       from osgeo import gdal
>> ../gdal/swig/python/build/lib.linux-x86_64-2.7/osgeo/__init__.py:21: in
>> <module>
>>       _gdal = swig_import_helper()
>> ../gdal/swig/python/build/lib.linux-x86_64-2.7/osgeo/__init__.py:17: in
>> swig_import_helper
>>       _mod = imp.load_module('_gdal', fp, pathname, description)
>> E   ImportError: /scratch/gdal/gdal/gdal/.libs/libgdal.so.20: undefined
>> symbol: _Z17CPLHaveRuntimeAVXv
>> Any idea why  libgdal.so.20 has undefined symbol?
> First time I see this error
> Do you get this also when using gdalinfo, gdal_translate, etc ?
> If so, consider doing a clean build. It might be that you have attempted
> several builds of GDAL with different options after ./configure
