[gdal-dev] OGR SQL on CSV file with field name with parentheses?
Even Rouault even.rouault at spatialys.com
Fri Apr 19 01:45:57 PDT 2019
On vendredi 19 avril 2019 14:52:13 CEST John Baumgartner wrote:
> Try surrounding the field name with square brackets:
> ogrinfo -al "Data_directory" -dialect sqlite -sql "SELECT [Vs30(m/s)] as
> Vs30 FROM file1"
Brackets won't work with OGR SQL or SQLite. You must use double quotes
On a Bash shell, if you use double quotes for the SQL statement itself,
you need to escape them
ogrinfo test.csv -sql "select \"VS30(m/s)\" as VS30ms from test"
On Windows cmd.exe, you might also apparently try the above in most cases,
but there are some subtleties and dangers in some cases (not for the
above one), as underlined by
https://blogs.msdn.microsoft.com/twistylittlepassagesallalike/2011/04/23/everyone-quotes-command-line-arguments-the-wrong-way/
(paragraph "cmd.exe" and following)
Even
http://www.spatialys.com
