[gdal-dev] OGR SQL on CSV file with field name with parentheses?
Even Rouault
even.rouault at spatialys.com
Fri Apr 19 10:42:25 PDT 2019
On vendredi 19 avril 2019 16:05:14 CEST Moskovitz, Bob at DOC wrote:
> Thanks John, it worked perfectly!
oh, indeed. Turns out SQLite is rather permissive in that area:
https://www.sqlite.org/lang_keywords.html
(that said, OGR SQL only accepts double quotes when identifier quoting is
needed)
http://www.spatialys.com
