[gdal-dev] Restoring functions removed in 2.5 beta1
Even Rouault even.rouault at spatialys.com
Mon Apr 22 08:16:56 PDT 2019
On lundi 22 avril 2019 09:07:30 CEST Sean Gillies wrote:
> Hi Even,
> On Sun, Apr 21, 2019 at 4:09 PM Even Rouault <even.rouault at spatialys.com>
> wrote:
> > Sean,
> > > The Fiona and Rasterio projects won't build with the pre-release
> > > because,
> > > for better or worse, they reference and use OSRFixup, which has been
> > > removed. I've filed issue #1466 about this.
> > > Yes, we can add shims to Fiona and Rasterio so we can support versions
> > > 2.0-2.5, but this does nothing for software that's already installed on
> > > computers. If a no-op version of OSRFixup were restored to GDAL 2.5,
> > these
> > > projects and previously installed versions of them would likely work
> > > just
> > > fine with 2.5.
> > I'm not so sure restoring the functions is enough. This might give a false
> > impression. More testing & other changes will generally be needed because
> > of
> > all the revamp that has done in that area of SRS functionnality, like
> > changes
> > in axis order.
> I had the impression from reading RFC 73 that the data-crs axes mapping
> concerns would be, with a few exceptions, internal to GDAL and OGR and that
> things would be unchanged for Rasterio and Fiona. Specifically, the intent
> is that OGR_G_GetX and OGR_G_GetY (used by Fiona:
> https://github.com/Toblerity/Fiona/blob/master/fiona/_geometry.pyx#L123)
> will by default return the same values in GIS-friendly order as in 2.4. Yes?
Yes, retrieving geometries from drivers shouln't change.
But if you use the OGRCoordinateTransformation class with OGRSpatialReference
objects created from scratch, they will honour EPSG axis order by default (if
using EPSG based CRS).
I think you're just in that case with:
https://github.com/Toblerity/Fiona/blob/master/fiona/_transform.pyx
To get previous behaviour you'll need to call
OSRSetAxisMappingStrategy(hSRS, OAMS_TRADITIONAL_GIS_ORDER) on the SRS object
you've created.
Even
http://www.spatialys.com
