[gdal-dev] GDAL Docker images
Vincent Sarago vincent.sarago at gmail.com
Thu Apr 25 12:41:15 PDT 2019
This is great, thanks Even.
Because I’m mostly working with AWS Lambda, I might open a PR to add a CENTOS based image (ref: https://github.com/RemotePixel/amazonlinux-gdal <https://github.com/RemotePixel/amazonlinux-gdal>) if this is ok ;-)
Vincent
> Le 25 avr. 2019 à 15:38, Even Rouault <even.rouault at spatialys.com> a écrit :
> Hi,
> I've prepared a set of Dockerfile for different configurations.
> See
> https://github.com/OSGeo/gdal/blob/master/gdal/docker/README.md
> The scope of each is rather arbitrary, but this can be used as a base for
> derived works.
> View on Docker Hub:
> https://hub.docker.com/r/osgeo/gdal
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190425/48fb69e9/attachment.html>
