[gdal-dev] relationship between gdalwarp and gdal_translate
Idan Miara idan at miara.com
Mon Apr 29 08:23:58 PDT 2019
got it, thanks!!!
On Mon, 29 Apr 2019 at 18:15, Even Rouault <even.rouault at spatialys.com>
wrote:
> On lundi 29 avril 2019 18:06:46 CEST Idan Miara wrote:
> > Hi,
> > I'm writing a wrapper and a QT5 frontend for gdalwarp/gdal_translate:
> > https://github.com/talos-gis/gdalos
> > I was wandering if gdalwarp can do anything that gdal_translate can do
> (and
> > much more), why is gdal_translate needed? do they use the same backend
> for
> > tasks that gdal_translate can do?
> They use completely different techniques. gdal_translate will be
> faster than gdalwarp when no reprojection, cutlining, etc. is needed
> gdalwarp can only work with output drivers that have full random-write
> capabilities (e.g. TIFF), whereas gdal_translate can support, in addition
> to those ones, all drivers that have create copy mode (e.g PNG)
> See
> https://trac.osgeo.org/gdal/wiki/FAQRaster#Whywontgdalwarporgdal_mergewritetomostformats
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190429/e33f4e72/attachment.html>
