[gdal-dev] gdal_contour -p options no attributes and interval < 1 strange results?
Even Rouault even.rouault at spatialys.com
Mon Apr 29 13:03:51 PDT 2019
Hi Richard,
> If I use gdal_contour (in QGIS/processing) to generate contours of a
> rasterset you get a call like:
> gdal_contour -b 1 -a ELEV -i 0.0001 -f "ESRI Shapefile" /tmp/smoke.asc
> /tmp/OUTPUT.shp
> The column ELEV will contain the contour 'height'
> But when using the -p option (to create polygons instead of lines) this
> column ELEV is just empty.
> Is this a bug? Or suppoosed to be... if you want to create labels it
> would be handier if this column is filled.
Expected behaviour, which was clarified a few weeks ago,as someone also
stumbled on this:
https://gdal.org/gdal_contour.html:
-a name:
    provides a name for the attribute in which to put the elevation. If not
provided no elevation attribute is attached. Ignored in polygonal contouring
(-p) mode.
-amin name:
    (Since GDAL 2.4) provides a name for the attribute in which to put the
minimum elevation of contour polygon. If not provided no minimum elevation
attribute is attached. Ignored in default line contouring mode.
-amax name:
maximum elevation of contour polygon. If not provided no maximim elevation
So the QGIS algorithm should handle the line vs polygon cases a bit
differently to use -a or -amin + -amax
> When using interal values like above (0.0001) the contours *look* ok,
> but the values in the dbf/shp file all show 0.001  ??
Ah, that's because gdal_contour creates the elevation field with width=12 and
precision=3, which is obviouly not appropriate for the interval you specify.
Could be worth a GDAL ticket.
> But when you do output a geopackage
> gdal_contour -b 1 -a ELEV -i 0.0001 -f "GPKG" /tmp/smoke.asc
> /tmp/OUTPUT.gpkg
> The values are OK
Yes, GeoPackage doesn't support width.precision for numeric fields, and values
are ultimately stored as IEEE754 double precision.
> (well, showing 0.0011 and 0.00090000000 so 'precision'
> is handled a little strange...), also when you use 1.0E-4 or 1.00000E-4
Showing where ? In QGIS ? Well, that's probably just a formatting issue. With
ogrinfo/sqlite3, you get the values look OK:
$ echo "select distinct elev from contour order by elev;" | sqlite3 out.gpkg
0.0001
0.0002
0.0003
0.0004
0.0005
0.0006
0.0007
0.0008
0.0009
0.001
0.0011
0.0012
0.0013
Even
http://www.spatialys.com
