[gdal-dev] Interesting debugging log from FileGBD driver
Andrea Aime andrea.aime at geo-solutions.it
Tue Apr 30 06:06:29 PDT 2019
I'm looking at a performance issue rendering a very large ESRI File
geodatabase, and in the logs I see:
CPLQuadTree: Estimated spatial index tree depth: 20
CPLQuadTree: Falling back to max number of allowed index tree levels (12).
Wondering if this might be a reason for slow data extraction, and if there
are settings to make it us the full
quadtree depth? The environment is also a multi-threaded (multiple threads
reading from the file at the same time), this could also be a cause.
The file in question is massive, so OpenFileGDB does not seem like an option
Cheers
Andrea
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information. == Ing. Andrea Aime @geowolf Technical Lead
GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39
0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549
http://www.geo-solutions.it http://twitter.com/geosolutions_it
------------------------------------------------------- *Con riferimento
alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 -
Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni
circostanza inerente alla presente email (il suo contenuto, gli eventuali
allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i
destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per
errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le
sarei comunque grato se potesse darmene notizia. This email is intended
only for the person or entity to which it is addressed and may contain
information that is privileged, confidential or otherwise protected from
disclosure. We remind that - as provided by European Regulation 2016/679
“GDPR” - copying, dissemination or use of this e-mail or the information
herein by anyone other than the intended recipient is prohibited. If you
have received this email by mistake, please notify us immediately by
telephone or e-mail.*
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190430/a0a59e71/attachment.html>
