[gdal-dev] NetCDF driver getting wrong values if compared to HDF5
Even Rouault
even.rouault at spatialys.com
Fri Aug 2 02:19:50 PDT 2019
On jeudi 1 août 2019 22:10:22 CEST Ivan Lucena wrote:
> Hi Even,
> Thank you very much for your attention on this issue. Thank you for your
> time.
Do you have a link to this dataset ? On
http://www.vito-eodata.be/PDF/datapool/ I can only find .HDF5 files, not .nc
ones
http://www.spatialys.com
