[gdal-dev] MVT fields/geometry alignment
Even Rouault even.rouault at spatialys.com
Wed Aug 7 01:19:29 PDT 2019
Michael,
> In this MVT source poLayer->GetFeatureCount() reports that there are 85
> features, as does ogrinfo summary:
> But, iterating features finds 81 valid features, as reported by
The difference is due to clipping geometries to the tile extent.
GetFeatureCount() do a super fast scan, counting all features, whereas by
default GetNextFeature() also checks if the geometry intersects the tile
extent. And in that case there are a few features that are actually outside of
the tile extent. If you add -oo CLIP=NO then GetNextFeature() will report 85
features as well.
As a workaround for GetFeatureCount() to return 81 as well, you can specify a
dummy attribute filter that will force it to go to the slow scan mode:
ogrinfo 14/4823/6160.mvt landuse -al -so -where 1=1
Even
http://www.spatialys.com
