[gdal-dev] Motion: adopt RFC 75: Multidimensional array
Joe Lee hyoklee at hdfgroup.org
Wed Aug 7 13:36:48 PDT 2019
Hi, Even!
  I tested it and your new code works very well.
  Thank you for adding this new feature so quickly!
  Now I wish /vsis3 work on HDF4 like HDF5.
  That would be perfect because I tried /vsicurl as you suggested in [1] but it did not work.
[1] http://osgeo-org.1560.x6.nabble.com/gdal-dev-Does-vsis3-work-for-HDF4-td5405668.html
On Tue, Aug 6, 2019 at 12:14 PM Even Rouault <even.rouault at spatialys.com<mailto:even.rouault at spatialys.com>> wrote:
On mardi 30 juillet 2019 18:10:15 CEST Joe Lee wrote:
> I found the error. It was my token key in gdal.SetConfigOption().
> GDAL Multidimensional support is quite amazing and works well with AWS
> Lambda & HDF5 data on S3!
> I can't wait to see HDF4 multidimensional support.
This has just landed in master (as well as exporting 1D arrays to GeoTIFF)
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190807/0d4b1d52/attachment.html>
