[gdal-dev] NetCDF driver detected file type
Kurt Schwehr
schwehr at gmail.com
Wed Aug 7 14:24:32 PDT 2019
Hmm... these are netcdf 5 according to file. Does that not imply that that
I don't need to worry about NC4?
file *.nc
OR_ABI-L2-FDCF-M6_G17_s20192011300341_e20192011309408_c20192011309501.nc:
Hierarchical Data Format (version 5) data
OR_ABI-L2-FDCF-M6_G17_s20192011310341_e20192011319407_c20192011319507.nc:
OR_ABI-L2-FDCF-M6_G17_s20192011320341_e20192011329408_c20192011329487.nc:
OR_ABI-L2-FDCF-M6_G17_s20192011330341_e20192011339408_c20192011339497.nc:
OR_ABI-L2-FDCF-M6_G17_s20192011340341_e20192011349408_c20192011349492.nc:
OR_ABI-L2-FDCF-M6_G17_s20192011350341_e20192011359408_c20192011359486.nc:
I have the extra fun that my build is bazel based. I do have:
"-DFRMT_hdf4",
"-DFRMT_hdf5",
"-DFRMT_netcdf",
This indeed give nothing:
gdalinfo --format netcdf | grep NETCDF_HAS_NC4
I have more digging to do on the config checking side of things. I don't
have the dispatch tables for hdf4 in netcdf.
On Wed, Aug 7, 2019 at 1:51 PM Ivan Lucena <ivan.lucena at outlook.com> wrote:
> Even, Kurt,
> I've been thru the same issue last week. I might be wrong but the only way
> that I found to add support for NC4 into the netcdf-c-4.6.3 build was by
> enabling HDF4 .
> You might try run "./configure --help | grep 4" on the netCDF SDK to see
> if there is another way.
> I rebuild everything, HDF5, HDF4 and netCDF SDKs and GDAL and the netCDF
> driver and now I am not getting warnings like that anymore.
> Regards,
> Ivan
> *From:* gdal-dev <gdal-dev-bounces at lists.osgeo.org> on behalf of Even
> Rouault <even.rouault at spatialys.com>
> *Sent:* Wednesday, August 7, 2019 4:39 PM
> *To:* gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
> *Subject:* Re: [gdal-dev] NetCDF driver detected file type
> Kurt,
> I would say that your netCDF build lacks libhdf5 support needed to open
> netCDF
> 4 files, and/or that your GDAL build has been done against a netCDF
> version
> that lacked it (if you added support of HDF5 in the netCDF build, after
> doing
> an initial build of GDAL, you also need to rebuild GDAL)
> It is likely that with your build the following
> gdalinfo --format netcdf | grep NETCDF_HAS_NC4=YES
> reports currently nothing
> Rebuild netCDF with HDF5 support, and GDAL against this new netCDF build.
> Even
> > For a custom build of gdal, I'm seeing:
> > Warning 1: NetCDF driver detected file type=5, but libnetcdf detected
> > type=3
> > Any idea what is causing this? With gdal 2.3.2, from debian testing, I
> > don't see the message.
> > This warning message was added here:
> https://github.com/OSGeo/gdal/commit/813aa221af3ac13a3747f4d4a3f312f098869ad
> > c
> > using:
> gs://gcp-public-data-goes-17/ABI-L2-FDCF/2019/201/13/OR_ABI-L2-FDCF-M6_G17_s
> > netcdf 4.6.1
> > HDF5 claims to be 1.11.2 and is a bit newer than
> https://bitbucket.hdfgroup.org/projects/HDFFV/repos/hdf5/browse?at=807187e2f
> > 200e63adb4918dd475d47546c8588e9 GDAL from head ~ 2018-Oct
> > gdalinfo
> NETCDF:OR_ABI-L2-FDCF-M6_G17_s20192011310341_e20192011319407_c20192011319507
> > .nc:Area Warning 1: NetCDF driver detected file type=5, but libnetcdf
> > detected type=3 Driver: netCDF/Network Common Data Format
> > Files: none associated
> > Size is 5424, 5424
> > Coordinate System is:
> > PROJCS["unnamed",
> > GEOGCS["unknown",
> > DATUM["unknown",
> > SPHEROID["Spheroid",6378137,298.2572221]],
> > PRIMEM["Greenwich",0],
> > UNIT["degree",0.0174532925199433]],
> > PROJECTION["Geostationary_Satellite"],
> > PARAMETER["central_meridian",-137],
> > PARAMETER["satellite_height",35786023],
> > PARAMETER["false_easting",0],
> > PARAMETER["false_northing",0],
> > EXTENSION["PROJ4","+proj=geos +lon_0=-137 +h=35786023 +x_0=0 +y_0=0
> > +ellps=GRS80 +units=m +no_defs +sweep=x"]]
> > Origin = (-5434894.700982173904777,-5434895.218222249299288)
> > Pixel Size = (2004.017315487541055,2004.017315487541055)
> > Metadata:
> > Area#add_offset=4000
> > Area#cell_methods=sunglint_angle: point (no pixel produced)
> > local_zenith_angle: point (good quality pixel produced)
> solar_zenith_angle:
> > point (good quality pixel produced) t: point
> > Area#coordinates=sunglint_angle local_zenith_angle solar_zenith_angle
> t y
> > x
> > Area#grid_mapping=goes_imager_projection
> > Area#long_name=ABI L2+ Fire-Hot Spot Characterization: Fire Area
> > Area#scale_factor=60.98
> > [SNIP]
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190807/10d8de5f/attachment.html>
