[gdal-dev] NetCDF driver detected file type
Kurt Schwehr
schwehr at gmail.com
Wed Aug 7 15:18:24 PDT 2019
Thanks! Adding -DNETCDF_HAS_NC4 makes the warning go away.
Now I wonder what that means to users of this code that have been living
without that for forever.
I will try gdal_translate with and without that flag and see what happens.
It looks like I should see differences with unsigned types.
On Wed, Aug 7, 2019 at 2:36 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> On mercredi 7 août 2019 14:24:32 CEST Kurt Schwehr wrote:
> > Hmm... these are netcdf 5 according to file.
> HDF5, not netCDF 5. netCDF v4 file format is a profile on top of HDF5.
> > I have the extra fun that my build is bazel based.
> Ah that likely explains it... You need to add -DNETCDF_HAS_NC4 to the
> compilation flags of the frmts/netcdf/*.cpp files
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190807/0bccdf6c/attachment-0001.html>
