[gdal-dev] gdal_merge
Gong, Shawn shawn.gong at mdacorporation.com
Mon Aug 12 13:33:03 PDT 2019
Hi list,
I use gdal_merge to mosaic a set of DTED 1 and 2 chips.
DTED contains -32767 as nodata. But after merging, -32767 are reset as 0.
I tried to use "-n -32767" but getting the same result.
Is there a way to keep the -32767 values?
Thanks,
Shawn
This electronic correspondence, including any attachments, is intended solely for the use of the intended recipient(s) and may contain legally privileged, proprietary and/or confidential information. If you are not the intended recipient, please immediately notify the sender by reply e-mail and permanently delete all copies of this electronic correspondence and associated attachments. Any use, disclosure, dissemination, distribution or copying of this electronic correspondence and any attachments for any purposes that have not been specifically authorized by the sender is strictly prohibited.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190812/0f22e51d/attachment.html>
