[gdal-dev] OGR, WFS and axis
aborruso aborruso at gmail.com
Tue Aug 13 02:44:40 PDT 2019
Hi all,
I have this WFS source
http://map.sitr.regione.sicilia.it/orbs/services/geositi/catalogo_geositi/MapServer/WFSServer?service=wfs&request=GetCapabilities
If I run
ogr2ogr -skipfailures -f CSV /vsistdout/
wfs:"http://map.sitr.regione.sicilia.it/orbs/services/geositi/catalogo_geositi/MapServer/WFSServer"
-lco GEOMETRY=AS_XY | head | cut -d "," -f1,2
I have
X,Y
4159848.6057,407652.2197
4136669.4918,351648.1382
4182103.6455,368602.1861
4154094.0909,333347.9184
4222851.1989,329366.679
4271030.7208,460470.4647
4161643.0469,416859.4389
4270544.3923,458291.9136
4213272.6393,324524.3777
The axes are inverted and it's the same if I us
INVERT_AXIS_ORDER_IF_LAT_LONG parameter.
Is there a way to read it properly, without using some SQL like "SELECT
SwapCoordinates(geometry)".
Thank you
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
