[gdal-dev] On external PDF libraries
Andreas Neumann a.neumann at carto.net
Wed Aug 21 05:38:39 PDT 2019
Hi Even,
I think I got building with poppler to work.
gdalinfo and ogrinfo show both:
PDF -raster,vector- (w+): Geospatial PDF
However, QGIS still thinks there is no PDF read support in QGIS. When
trying to export to GeoPDF there is a message:
GDAL PDF driver was not build with PDF read support. A build with PDF
read support is required for GeoPDF creation.
Any ideas what might still be wrong?
Why is QGIS complaining about PDF read support when I want to export GeoPDF?
Thanks and greetings,
Andreas
Am 21.08.19 um 13:12 schrieb Even Rouault:
> Andreas,
>> I am trying to test GeoPDF support in QGIS and have questions on the
>> external library dependencies in GDAL. I am trying to interpret the
>> notes on https://gdal.org/drivers/raster/pdf.html
>> Which of the three options (Poppler, PoDoFo, PDFium) is recommended? I
>> work on Ubuntu 18.04 and I can build libraries from source if necessary.
>> PoDoFo seems limited - so better not use it?
> For non-rendering tasks such as creating a PDF, it should be OK, but I know I
> had issues at runtime with recent versions of PoDoFo
>> PDFium seems to be
>> complicated to install -
> Yes, and the driver assumes an old version of PDFium. Would require some work
> to make it work with newer ones.
>> so perhaps poppler?
> That's probably the simplest option and it will give you good results. No need
> to build it from source. The version already compiled in your distro is fine.
> Install the 'libpoppler-private-dev' package before building GDAL with
> ./configure --with-poppler
> Even
