[gdal-dev] On external PDF libraries
Andreas Neumann a.neumann at carto.net
Wed Aug 21 06:11:44 PDT 2019
Hi Even,
Yes, the make clean and recompile did the trick. Now the output of
ogr/gdalinfo seems correct and QGIS can export to GeoPDF.
Many thanks for your help!
Andreas
Am 21.08.19 um 14:49 schrieb Even Rouault:
> On mercredi 21 août 2019 14:38:39 CEST Andreas Neumann wrote:
>> Hi Even,
>> I think I got building with poppler to work.
>> gdalinfo and ogrinfo show both:
>> PDF -raster,vector- (w+): Geospatial PDF
> It should display '(rw+vs)' with r for 'read'
> If you've made several buid attempts while playing with ./configure, make sure
> to 'make clean' before rebuilding.
