[gdal-dev] gdal2tiles missing 'GRA_mode' resample method
    Jacobs Tim
    tim.jacobs at vito.be
    Mon Aug 26 08:06:47 PDT 2019
Dear GDAL Dev's,
Recently, we were using gdal2tiles.py to build TMS tiles.
Its code however seems to not support the "mode" resampling
that is available in other GDAL utilities such as gdalwarp and gdal_translate.
Can this be added to gdal2tiles.py too?
Thanks,
Tim Jacobs
Indien u VITO Mol bezoekt, hou aub er dan rekening mee dat de hoofdingang voortaan enkel bereikbaar is vanuit de richting Dessel-Retie, niet vanuit richting Mol, zie vito.be/route.<http://www.vito.be/route>
If you plan to visit VITO at Mol, then please note that the main entrance can only be reached coming from Dessel-Retie and no longer coming from Mol, see vito.be/en/contact/locations.<http://www.vito.be/en/contact/locations>
VITO Disclaimer: http://www.vito.be/e-maildisclaimer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190826/94b7afb4/attachment.html>
