[gdal-dev] Spatialite functions missing when reading GeoPackage
Rahkonen Jukka (MML) jukka.rahkonen at maanmittauslaitos.fi
Sun Dec 1 11:40:46 PST 2019
This works with GDAL from OSGeo4W, GDAL 3.0.2, released 2019/10/28
ogrinfo any.gpkg -dialect sqlite -sql "select spatialite_version()"
INFO: Open of `any.gpkg'
      using driver `GPKG' successful.
Layer name: SELECT
Geometry: None
Feature Count: 1
Layer SRS WKT:
(unknown)
spatialite_version(): String (0.0)
OGRFeature(SELECT):0
  spatialite_version() (String) = 4.3.0
With GDAL-del from gisinternals, GDAL 3.1.0dev, released 2019/99/99, Spatialite is not found if I make a query to GeoPackage database. The error is
ERROR 1: In ExecuteSQL(): sqlite3_prepare_v2(select spatialite_version()):
  no such function: spatialite_version
However, when datasource is not gpkg then Spatialite is found
ogrinfo any.shp -dialect sqlite -sql "select spatialite_version()"
INFO: Open of `any.shp'
      using driver `ESRI Shapefile' successful.
Layer name: SELECT
Geometry: None
Feature Count: 1
Layer SRS WKT:
(unknown)
  spatialite_version() (String) = 4.3.0-RC1
Obviously mod_spatialite is not loaded in the gpkg case but I wonder if the issue is in GDAL-dev or in the gisinternals build.
-Jukka Rahkonen-
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191201/24f6abb4/attachment.html>
