[gdal-dev] Error in Derived Band in Virtual raster (re-post)
bhandari
bhandari.ravi at outlook.com
Mon Dec 2 00:43:10 PST 2019
Hi
Jukka Rahkonen thank you for your reply
But the code of add2 function is in the same VRT file. Need I store in a
separate file as well.
<VRTDataset rasterXSize="25828" rasterYSize="16749">
<SRS>GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433],AUTHORITY["EPSG","4326"]]</SRS>
<GeoTransform> 7.8318056012634287e+01, 1.1839023066784193e-04,
0.0000000000000000e+00, 3.0866547275126596e+01, 0.0000000000000000e+00,
-7.3767782488687317e-05</GeoTransform>
<VRTRasterBand dataType="Float32" band="1"
subClass="VRTDerivedRasterBand">
<PixelFunctionType>add2</PixelFunctionType>
<PixelFunctionLanguage>Python</PixelFunctionLanguage>
<PixelFunctionCode>
</PixelFunctionCode>
<SimpleSource>
<SourceFilename
relativeToVRT="1">S1A_IW_GRDH_1SDV_20180924T005140_20180924T005205_023833_0299C5_5216_Orb.tif</SourceFilename>
<SourceBand>1</SourceBand>
<SourceProperties RasterXSize="25828" RasterYSize="16749"
DataType="Float32" BlockXSize="25828" BlockYSize="16749" />
<SrcRect xOff="0" yOff="0" xSize="25828" ySize="16749" />
<DstRect xOff="0" yOff="0" xSize="25828" ySize="16749" />
</SimpleSource>
<SimpleSource>
<SourceFilename
<SourceBand>2</SourceBand>
</SimpleSource>
</VRTRasterBand>
</VRTDataset>
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
