[gdal-dev] ECW to JP2000
Even Rouault
even.rouault at spatialys.com
Fri Dec 6 06:51:50 PST 2019
On vendredi 6 décembre 2019 14:05:37 CET Clay, Bruce wrote:
> when I use gdal_translate to convert an ECW file to JP2000 it ends up 9
> times larger. I could not find any options to control the compression like
> we can with Geotiff. Is there a way to get a compressed JP2000 image?
Certainly.
You need to look at the specific JPEG2000 driver you use. For example for
JP2OpenJPEG, the doc is at:
https://gdal.org/drivers/raster/jp2openjpeg.html
For example if you use QUALITY=5, then you'll get a file whose compressed size
is 5% of the uncompressed file size.
Even
http://www.spatialys.com
