[gdal-dev] Regarding geometry layer creation options
jratike80
jukka.rahkonen at maanmittauslaitos.fi
Mon Dec 9 02:01:25 PST 2019
Have you tried with the syntax that is used in an example in the CSV
documentation https://gdal.org/drivers/vector/csv.html?
"This example shows using ogr2ogr to transform a shapefile into a .csv file
with geography field formatted using GeoJSON format."
ogr2ogr -f CSV -dialect sqlite -sql "select AsGeoJSON(geometry) AS geom, *
from input" output.csv input.shp
-Jukka Rahkonen-
Ravi Teja Krishna Wuyyuru wrote
> Hello Gdal team,
> Iam using ogr2ogr tool for .shp or .geojson. or .kml to .csv conversion.
> But i want the Geometry to be as collections as show below. ( On giving
> GEOMETRY=AS_WKT iam getting in a normal format is there any option to get
> in the format i need )
> format I need : { "type": "Polygon", "coordinates": [ [ [ 76.612, 33.173
> ], [ 76.64, 33.162 ], [ 76.709, 33.181 ] ] ] }
> or atleast to have it in this format is aceptable
> for us POLYGON (([76.612 , 33.173],[76.64 , 33.162],[76.709 , 33.181]))
> format iam getting : POLYGON ((76.612 33.173,76.64 33.162,76.709
> 33.181))
> Thanks.
> gdal-dev mailing list
> gdal-dev at .osgeo
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
