[gdal-dev] Regarding geometry layer creation options
jratike80 jukka.rahkonen at maanmittauslaitos.fi
Mon Dec 9 04:39:25 PST 2019
The example does not really use any database. It is utilising SQLite and a
Spatialite function but it happens through a virtual table system in the
background. You do not need to install anything extra. Did you try the
command?
-Jukka-
Ravi Teja Krishna Wuyyuru wrote
> Hi,
> Thanks for your reply. But we would like to use it without using
> databases. can the same result be obtained without using any databases?
> Thanks
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
