[gdal-dev] Extended tab/mrr driver questions
Even Rouault even.rouault at spatialys.com
Tue Dec 10 04:13:34 PST 2019
Nyall,
> I just read this comment on the Pitney Bowes pull request regarding
> extended tab/mrr support:
> "After discussing with the GDAL PSC, we will be splitting this into
> two separate PRs for the two drivers. We will also be following the
> plugin model for both EFAL and MRR format driver."
> (https://github.com/OSGeo/gdal/pull/1882#issuecomment-563807100)
> Can anyone from gdal psc elaborate on this? Why were they advised to
> follow the plugin model instead of doing the "right thing" and
> extending the existing tab driver?
For everyone understanding, I had preliminary contacts with them beginning of
2018 about the MapInfo Extended part, when they tried to know how to get it
into GDAL. At that time, I did suggest to them that extending MITAB would be
the most natural thing to do, which would make MapInfo Extended "immediately"
available to everyone using GDAL. At that time, they already floating around
the idea of using parts of their code base. I told them this would be far less
practical for their users, even if their SDK was open sourced (since it would
have packaging implication). At the end, they followed the route of using
their closed source SDK and submitted this PR mixing 2 things, and using a
unusual model for drivers relying on SDK.
We had some email discussions with them one month ago within the GDAL PSC to
tell them that their PR couldn't be merged as it and they should at the very
least rework it as 2 PRs and follow the usual model, but that it would still
require finding a reviewer keen to review them & press the merge button. That
part is going to be problematic.
Even
http://www.spatialys.com
