[gdal-dev] python GDAL issue
    Edson, Adam Robert
    are131 at psu.edu
    Wed Dec 11 08:42:51 PST 2019
Looking through the code, I noticed the SWIG interface language. Going from that, I began looking into SWIG and what it can do. In the documentation, it talks about Byte string output conversion (in section 32.12.4). My understanding from that section of the SWIG documentation (http://swig.org/Doc4.0/SWIGDocumentation.pdf) is that SWIG assumes UTF-8 for every char when sending it to python.
Do you have any experience working with the SWIG interface language? Is your understanding similar?
Thanks!
Adam
Sent: Wednesday, November 6, 2019 11:02 PM
To: Edson, Adam Robert <are131 at psu.edu>; gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
Cc: Bradley, Eliza S <esb165 at psu.edu>
Subject: RE: [gdal-dev] python GDAL issue
I think it should check the “type” value. My “maybe this could work” concept was something like:
--- a/gdal/frmts/nitf/nitffile.c
+++ b/gdal/frmts/nitf/nitffile.c
@@ -2150,6 +2150,8 @@ static char** NITFGenericMetadataReadTREInternal(char **papszMD,
             const char* pszName = CPLGetXMLValue(psIter, "name", NULL);
             const char* pszLongName = CPLGetXMLValue(psIter, "longname", NULL);
             const char* pszLength = CPLGetXMLValue(psIter, "length", NULL);
+            const char* pszType = CPLGetXMLValue(psIter, "type", "string");
             int nLength = -1;
             if (pszLength != NULL)
                 nLength = atoi(pszLength);
@@ -2219,7 +2221,17 @@ static char** NITFGenericMetadataReadTREInternal(char **papszMD,
                 if (psOutXMLNode != NULL)
-                    const char* pszVal = strchr(papszMD[(*pnMDSize) - 1], '=') + 1;
+                    char* pszVal = strchr(papszMD[(*pnMDSize) - 1], '=') + 1;
+                    if (strcmp(pszType, "IEEE754") == 0)
+                        // TODO: fix
+                        printf("IEEE754: 0x%02x 0x%02x 0x%02x 0x%02x\n", pszVal[0], pszVal[1], pszVal[2], pszVal[3]);
+                        pszVal = "FIXME1";
+                    } else if (strcmp(pszType, "UINT") == 0) {
+                        printf("UINT: 0x%02x 0x%02x 0x%02x 0x%02x\n", pszVal[0], pszVal[1], pszVal[2], pszVal[3]);
+                        pszVal = "FIXME2";
                     CPLXMLNode* psFieldNode;
                     CPLXMLNode* psNameNode;
                     CPLXMLNode* psValueNode;
(I think the pzVal might need to be changed to a union / class that has char*, a double or an unsigned int; I haven’t dug further than this yet).
Brad
Sent: Thursday, 7 November 2019 6:34 AM
To: Brad Hards <bradh at frogmouth.net>; gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] python GDAL issue
Looking at the code, it appears that GDAL actually hard codes any TRE that takes anything that cannot be parsed as a string (e.g. nitfimage.c NITFReadICHIPB). So, for BANDSB with its EXISTENCE_MASK and SCALE_FACTOR would need to be hard coded as opposed to being defined just within the nitf_spec.xml. Is this the correct interpretation?
Thanks!
Adam
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191211/eccd0edf/attachment-0001.html>
