[gdal-dev] VSI CIFS driver
Craig de Stigter craig.destigter at koordinates.com
Fri Dec 13 23:42:58 PST 2019
Thanks Even
That sounds like a possible path forward, although it works for FUSE
filesystems only, so we'd have to find a good FUSE implementation of CIFS
(currently we're using the kernel provided cifs)
If anyone can recommend a well-maintained FUSE CIFS implementation I'd
gladly look into it. After some googling I don't see much that fills me
with confidence, but I will continue to search at work next week.
I'll keep you updated  on what I discover. Thanks
Craig
On Fri, 13 Dec 2019 at 23:38, Even Rouault <even.rouault at spatialys.com>
wrote:
> Craig,
> > We have to access some customer data via their CIFS shares on a regular
> > basis.
> > To date we have been doing it via a setuid script which mounts and
> unmounts
> > the CIFS share locally, then treats the files as local. We're
> > containerising our workers, and using kernel mounts is no longer possible
> > (at least, not even slightly securely.)
> Is upgrading to Kernel 4.18 an option ?
> See https://www.phoronix.com/scan.php?page=news_item&px=Linux-4.18-FUSE
> > This means we need a userspace CIFS implementation for a lot of our GDAL
> > code, and a VSI CIFS driver would seem to be the right thing to do.
> > Presumably it will be a fairly thin wrapper of libsmb.
> > 2. Would it be something GDAL might accept as a core contribution, or
> > should we expect to maintain it outside of core?
> Hard to know where to draw the line. If recent kernels would make this no
> longer needed, then its value in core might be low.
> > 3. We noticed https://github.com/OSGeo/gdal/pull/1289 should allow VSI
> > plugins to be registered from Python,
> It allows VSI plugins to be registered with a C interface. So if you'd
> want ot
> use that from Python, you'd likely have to play with ctypes or similar
> technology.
> > Are there any docs on how to actually do this?
> Well, the Doxygen docs of VSIAllocFilesystemPluginCallbacksStruct and
> VSIInstallPluginHandler in cpl_vsi.h . And the tutorial you'll add if you
> proceed that way ;-)
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
Regards,
Craig
Developer
Koordinates
+64 21 256 9488 <+64%2021%20256%209488> / koordinates.com / @koordinates
<https://twitter.com/koordinates>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191214/ba6c8955/attachment.html>
