[gdal-dev] Changes in SRS handling w.r.t TOWGS84
Even Rouault
even.rouault at spatialys.com
Tue Dec 17 10:36:44 PST 2019
Following a number of exchanges on the PROJ mailing list, related to PROJ 6
integration in QGIS, I've prepared a pull request changing a bit how we deal
with the 'early-binding' TOWGS84 term in
https://github.com/OSGeo/gdal/pull/2113
When importing from EPSG, GDAL 3.0.0 to 3.0.2 followed the scheme used in
GDAL 1.x and GDAL 2.x, that is they tried to attach a TOWGS84 transformation.
While the intent was to have some sort of backward compatibility, this may
be a pain for the future.
So do the following changes:
- importFromEPSG(): no longer attach a TOWGS84 transformation, unless the
user set the OSR_ADD_TOWGS84_ON_IMPORT_FROM_EPSG=YES configuration option
Add a OGRSpatialReference::AddGuessedTOWGS84() to attach such a
transformation, when possible (note: this will do it in a more prudent way
than GDAL 1.x/2.x, that is only if a transformation is found for the whole
area of use of the CRS)
- exportToProj4(): if the SRS has no transformation to WGS84,
attach a +towgs84 if the SRS has a EPSG code and AddGuessedToWGS84()
succeeds.
Can be disabled with the OSR_ADD_TOWGS84_ON_EXPORT_TO_PROJ4 = NO
- exportToWkt() with WKT1 format:
Add a OSR_ADD_TOWGS84_ON_EXPORT_TO_WKT1 = YES/NO configuration option, which
defaults to NO. If set to YES, then a transformation to WGS84 using
AddGuessedToWGS84() logic is researched to add a TOWGS84[] node.
The aim is to avoid the propagation of potentially suboptimal TOWGS84 terms by
default (except when exporting to PROJ4 string as we don't have a more
expressive way of encoding datum information), which can be the source of
later problems (not using grids when available due to this towgs84 being
strictly honoured).
I've a backport of this for the 3.0 branch ready, to go in the 3.0.3 release.
Even
http://www.spatialys.com
