[gdal-dev] An issue when trying to add TIFFTAG_DATETIME to BigTIFF raster
Андрій Марчак
m2r42kbear at gmail.com
Tue Dec 17 18:53:03 PST 2019
I have an issue when trying to add TIFFTAG_DATETIME to BigTIFF raster. Here
the input metadata:
ExifTool` Version Number : 11.79
File Name :
cushing_north_high_high_mosaic_7.45cm_utm14_wgs84_meters_2019-01-17.tif
Directory : D:/temp
File Size : 3.4 GB
File Modification Date/Time : 2019:12:17 11:25:48+02:00
File Access Date/Time : 2019:12:17 19:53:20+02:00
File Creation Date/Time : 2019:12:14 18:46:14+02:00
File Permissions : rw-rw-rw-
File Type : BTF
File Type Extension : btf
MIME Type : image/x-tiff-big
I run this code:
<gdal_translate
D:\temp\cushing_north_high_high_mosaic_7.45cm_utm14_wgs84_meters_2019-01-17.tif
D:\temp\cushing_north_high_high_mosaic_7.45cm_utm14_wgs84_meters_2019-01-17_Copy.tif
-mo *TIFFTAG_DATETIME="2019:01:31 09:00:00-07:00"* -co COMPRESS=LZW -co
BIGTIFF=YES>
And I got the following metadata for some reason:
ExifTool Version Number : 11.79
File Name :
Directory : D:/temp
File Size : 2.9 GB
File Modification Date/Time : 2019:12:17 09:36:11+02:00
File Access Date/Time : 2019:12:17 10:33:22+02:00
File Creation Date/Time : 2019:12:17 09:34:43+02:00
File Type : BTF
Image Width : 28194
Image Height : 38514
Bits Per Sample : 8 8 8 8
Compression : LZW
Photometric Interpretation : RGB
Strip Offsets : (Binary data 409063 bytes, use -b option
to extract)
Samples Per Pixel : 4
Rows Per Strip : 1
Strip Byte Counts : (Binary data 231034 bytes, use -b option
to extract)
Planar Configuration : Chunky
*Modify Date : 2019:01:31 09:00:00-07:00*
Predictor : None
Extra Samples : Unassociated Alpha
Sample Format : Unsigned; Unsigned; Unsigned; Unsigned
Pixel Scale : 0.0744678000000016 0.0744678000000023 0
Model Tie Point : 0 0 0 701489.300385367 3989064.72829922 0
Geo Tiff Directory : (Binary data 106 bytes, use -b option to
extract)
Geo Tiff Ascii Params : (Binary data 29 bytes, use -b option to
extract)
GDAL Metadata : <GDALMetadata>. <Item name="UNITTYPE"
sample="0" role="unittype">metre</Item>. <Item name="UNITTYPE" sample="1"
role="unittype">metre</Item>. <Item name="UNITTYPE" sample="2"
role="unittype">metre</Item>. <Item name="UNITTYPE" sample="3"
role="unittype">metre</Item>.</GDALMetadata>.
Image Size : 28194x38514
Megapixels : 1085.9
I need to add a tag *"Date Time", but not "Modify Date"*. I was doing the
same for a few BigTIFF rasters, but with the same results.
Ideally, I want to add a tag *"Capture Date Time"*, but, I found, that GDAL
can deal with the following baseline TIFF tags as dataset-level metadata:
[https://gdal.org/drivers/raster/gtiff.html#metadata]
Thanks,
Andriy
Best regards,
Andriy Marchak!
Skype: m2r42k_bear
phone: +38 063 147 95 95 (WhatsApp)
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191218/9b473355/attachment.html>
