[gdal-dev] GDAL python bindings memory usage
Even Rouault even.rouault at spatialys.com
Thu Dec 26 07:07:24 PST 2019
On jeudi 26 décembre 2019 14:30:35 CET Evert Etienne (SITEMARK) wrote:
> Using a bigger file (8GB) and a machine with 64GB Ram we can see the
> increase being higher. For both gdal.Warp and gdal.Translate
GDAL may use up to GDAL_CACHEMAX memory, plus some other smaller caches. I'm
not sure how memory_profile monitors memory consumption, but it is possible
that the apparent virtual memory is not returned to the OS. But if you run
those commands several times in the same procss, you should hopefully observe
some ceiling in memory consumption.
Even
http://www.spatialys.com
