[gdal-dev] Different results when reading a GeoTIFF with GDAL 2.1.2 vs 3.x
Even Rouault
even.rouault at spatialys.com
Sun Dec 29 12:51:08 PST 2019
> Is it possible that this is a compiler issue? Anyone else that can
> test this on an AMD CPU? Mine are old Phenom II X4 965s.
Perhaps rather a runtime issue. I suspect this is related to a SSSE3
optimization that has been added in GDAL 2.2 that is used in this use case
(unpacking of byte buffer with a 2 byte stride to packed buffer)
>From what I found on the net, I think this CPU doesn't support the SSSE3
instruction set (SSSE3 with three S, not to be confused with SSE3...)
Can you check the following ?
cat /proc/cpuinfo | grep ssse3
What is strange is that GDAL does have a runtime check to detect if SSSE3 is
available, so I'm not sure why you would get that issue. Unless that Docker
would wrongly expose SSSE3, but Docker is not a VM technology so it shouldn't
mess up with CPU capability discoveries. This is weird.
Can you try the following ?
docker run --rm osgeo/gdal su -c "apt install -y cpuid; cpuid" | grep SSSE3
In a DEBUG build of GDAL, you could disable at runtime the SSSE3 optimization
by defining the environment variable/configuration option GDAL_USE_SSSE3 to
NO, but this will not work on the release builds available on Docker.
http://www.spatialys.com
