[gdal-dev] Different results when reading a GeoTIFF with GDAL 2.1.2 vs 3.x
Momtchil Momtchev momtchil at momtchev.com
Sun Dec 29 13:15:02 PST 2019
     I get the same wrong results with and without Docker, with and
without the SSE/SSE3/AVX when using the configure script. I also tried
removing -O2. Is the SSE3 unpacking in GDAL or in libgeotiff?
On 29/12/2019 21:51, Even Rouault wrote:
>>       Is it possible that this is a compiler issue? Anyone else that can
>> test this on an AMD CPU? Mine are old Phenom II X4 965s.
> Perhaps rather a runtime issue. I suspect this is related to a SSSE3
> optimization that has been added in GDAL 2.2 that is used in this use case
> (unpacking of byte buffer with a 2 byte stride to packed buffer)
>  From what I found on the net, I think this CPU doesn't support the SSSE3
> instruction set (SSSE3 with three S, not to be confused with SSE3...)
> Can you check the following ?
> cat /proc/cpuinfo | grep ssse3
> What is strange is that GDAL does have a runtime check to detect if SSSE3 is
> available, so I'm not sure why you would get that issue. Unless that Docker
> would wrongly expose SSSE3, but Docker is not a VM technology so it shouldn't
> mess up with CPU capability discoveries. This is weird.
> Can you try the following ?
> docker run --rm osgeo/gdal su -c "apt install -y cpuid; cpuid" | grep SSSE3
> In a DEBUG build of GDAL, you could disable at runtime the SSSE3 optimization
> by defining the environment variable/configuration option GDAL_USE_SSSE3 to
> NO, but this will not work on the release builds available on Docker.
Momtchil Momtchev <momtchil at momtchev.com>
