[gdal-dev] Different results when reading a GeoTIFF with GDAL 2.1.2 vs 3.x
Momtchil Momtchev momtchil at momtchev.com
Sun Dec 29 14:59:12 PST 2019
     Here is the cpuid output
On 29/12/2019 22:57, Even Rouault wrote:
> On dimanche 29 décembre 2019 22:36:24 CET Momtchil Momtchev wrote:
>>       Disabling HAVE_SSSE3_AT_COMPILE_TIME had no effect,
> Make sure you run "make clean" after running ./configure
>> but after
>> short-circuiting the #ifdef I got a correct result.
> Hum so it seems that the SSSE3 detection doesn't work properly.
> Can you :
> 1. undo your code changes
> 2. modify port/cpl_cpu_features.cpp at line 98 to replace the code of the
> CPLDetectSSE3() function by
> static inline bool CPLDetectSSE3()
>      int cpuinfo[4] = { 0, 0, 0, 0 };
>      CPL_CPUID(0, cpuinfo);
>      if( cpuinfo[REG_EAX] <= 0 )
>          return false;
>      CPL_CPUID(1, cpuinfo);
>      return (cpuinfo[REG_ECX] & (1 << CPUID_SSSE3_ECX_BIT)) != 0;
> (note: this function should really be called CPLDetectSSSE3 ... missing S...
> but that doesn't matter)
> 3. modify port/cpl_cpu_features.h to add just after line 47 "#if __SSSE3__" a
> new line with "dummy" as content. Normally this shouldn't be compiled... but
> this is just to make sure the compiler doesn't define SSSE3 as available
> unconditionnally at runtime.
> 4. run configure again *without* disabling ssse3
> 5. make clean
> 6. make (possibly with -j something)
Momtchil Momtchev <momtchil at momtchev.com>
CPU 0:
   vendor_id = "AuthenticAMD"
   version information (1/eax):
      processor type  = primary processor (0)
      family          = Intel Pentium 4/Pentium D/Pentium Extreme Edition/Celeron/Xeon/Xeon MP/Itanium2, AMD Athlon 64/Athlon XP-M/Opteron/Sempron/Turion (15)
      model           = 0x4 (4)
      stepping id     = 0x3 (3)
      extended family = 0x1 (1)
      extended model  = 0x0 (0)
      (simple synth)  = AMD Phenom II (Callisto / Heka / Deneb RB-C3) [K10], 45nm
   miscellaneous (1/ebx):
      process local APIC physical ID = 0x0 (0)
      cpu count                      = 0x4 (4)
      CLFLUSH line size              = 0x8 (8)
      brand index                    = 0x0 (0)
   brand id = 0x00 (0): unknown
   feature information (1/edx):
      x87 FPU on chip                        = true
      VME: virtual-8086 mode enhancement     = true
      DE: debugging extensions               = true
      PSE: page size extensions              = true
      TSC: time stamp counter                = true
      RDMSR and WRMSR support                = true
      PAE: physical address extensions       = true
      MCE: machine check exception           = true
      CMPXCHG8B inst.                        = true
      APIC on chip                           = true
      SYSENTER and SYSEXIT                   = true
      MTRR: memory type range registers      = true
      PTE global bit                         = true
      MCA: machine check architecture        = true
      CMOV: conditional move/compare instr   = true
      PAT: page attribute table              = true
      PSE-36: page size extension            = true
      PSN: processor serial number           = false
      CLFLUSH instruction                    = true
      DS: debug store                        = false
      ACPI: thermal monitor and clock ctrl   = false
      MMX Technology                         = true
      FXSAVE/FXRSTOR                         = true
      SSE extensions                         = true
      SSE2 extensions                        = true
      SS: self snoop                         = false
      hyper-threading / multi-core supported = true
      TM: therm. monitor                     = false
      IA64                                   = false
      PBE: pending break event               = false
   feature information (1/ecx):
      PNI/SSE3: Prescott New Instructions     = true
      PCLMULDQ instruction                    = false
      DTES64: 64-bit debug store              = false
      MONITOR/MWAIT                           = true
      CPL-qualified debug store               = false
      VMX: virtual machine extensions         = false
      SMX: safer mode extensions              = false
      Enhanced Intel SpeedStep Technology     = false
      TM2: thermal monitor 2                  = false
      SSSE3 extensions                        = false
      context ID: adaptive or shared L1 data  = false
      SDBG: IA32_DEBUG_INTERFACE              = false
      FMA instruction                         = false
      CMPXCHG16B instruction                  = true
      xTPR disable                            = false
      PDCM: perfmon and debug                 = false
      PCID: process context identifiers       = false
      DCA: direct cache access                = false
      SSE4.1 extensions                       = false
      SSE4.2 extensions                       = false
      x2APIC: extended xAPIC support          = false
      MOVBE instruction                       = false
      POPCNT instruction                      = true
      time stamp counter deadline             = false
      AES instruction                         = false
      XSAVE/XSTOR states                      = false
      OS-enabled XSAVE/XSTOR                  = false
      AVX: advanced vector extensions         = false
      F16C half-precision convert instruction = false
      RDRAND instruction                      = false
      hypervisor guest status                 = false
   cache and TLB information (2):
   processor serial number: 0010-0F43-0000-0000-0000-0000
   MONITOR/MWAIT (5):
      smallest monitor-line size (bytes)       = 0x40 (64)
      largest monitor-line size (bytes)        = 0x40 (64)
      enum of Monitor-MWAIT exts supported     = true
      supports intrs as break-event for MWAIT  = true
      number of C0 sub C-states using MWAIT    = 0x0 (0)
      number of C1 sub C-states using MWAIT    = 0x0 (0)
      number of C2 sub C-states using MWAIT    = 0x0 (0)
      number of C3 sub C-states using MWAIT    = 0x0 (0)
      number of C4 sub C-states using MWAIT    = 0x0 (0)
      number of C5 sub C-states using MWAIT    = 0x0 (0)
      number of C6 sub C-states using MWAIT    = 0x0 (0)
      number of C7 sub C-states using MWAIT    = 0x0 (0)
   extended processor signature (0x80000001/eax):
      family/generation = AMD Athlon 64/Opteron/Sempron/Turion (15)
      model             = 0x4 (4)
   extended feature flags (0x80000001/edx):
      APIC on chip                          = true
      SYSCALL and SYSRET instructions       = true
      global paging extension               = true
      conditional move/compare instruction  = true
      multiprocessing capable               = false
      no-execute page protection            = true
      AMD multimedia instruction extensions = true
      1-GB large page support               = true
      RDTSCP                                = true
      long mode (AA-64)                     = true
      3DNow! instruction extensions         = true
      3DNow! instructions                   = true
   extended brand id (0x80000001/ebx):
      raw          = 0x10001c16 (268442646)
      BrandId      = 0x1c16 (7190)
      str1         = 0x3 (3)
      str2         = 0x6 (6)
      PartialModel = 0x41 (65)
      PG           = 0x0 (0)
      PkgType      = 0x1 (1)
   AMD feature flags (0x80000001/ecx):
      LAHF/SAHF supported in 64-bit mode     = true
      CMP Legacy                             = true
      SVM: secure virtual machine            = true
      extended APIC space                    = true
      AltMovCr8                              = true
      LZCNT advanced bit manipulation        = true
      SSE4A support                          = true
      misaligned SSE mode                    = true
      3DNow! PREFETCH/PREFETCHW instructions = true
      OS visible workaround                  = true
      instruction based sampling             = true
      XOP support                            = false
      SKINIT/STGI support                    = true
      watchdog timer support                 = true
      lightweight profiling support          = false
      4-operand FMA instruction              = false
      TCE: translation cache extension       = false
      NodeId MSR C001100C                    = false
      TBM support                            = false
      topology extensions                    = false
      core performance counter extensions    = false
      data breakpoint extension              = false
      performance time-stamp counter support = false
      MWAITX/MONITORX supported              = false
   brand = "AMD Phenom(tm) II X4 965 Processor"
   L1 TLB/cache information: 2M/4M pages & L1 TLB (0x80000005/eax):
      instruction # entries     = 0x10 (16)
      instruction associativity = 0xff (255)
      data # entries            = 0x30 (48)
      data associativity        = 0xff (255)
   L1 TLB/cache information: 4K pages & L1 TLB (0x80000005/ebx):
      instruction # entries     = 0x20 (32)
   L1 data cache information (0x80000005/ecx):
      lines per tag     = 0x1 (1)
      associativity     = 0x2 (2)
      size (KB)         = 0x40 (64)
   L1 instruction cache information (0x80000005/edx):
   L2 TLB/cache information: 2M/4M pages & L2 TLB (0x80000006/eax):
      instruction # entries     = 0x0 (0)
      instruction associativity = L2 off (0)
      data # entries            = 0x80 (128)
      data associativity        = 2-way (2)
   L2 TLB/cache information: 4K pages & L2 TLB (0x80000006/ebx):
      instruction # entries     = 0x200 (512)
      instruction associativity = 4-way (4)
      data # entries            = 0x200 (512)
      data associativity        = 4-way (4)
   L2 unified cache information (0x80000006/ecx):
      associativity     = 16-way (8)
      size (KB)         = 0x200 (512)
   L3 cache information (0x80000006/edx):
      associativity         = 48-way (11)
      size (in 512KB units) = 0xc (12)
   RAS Capability (0x80000007/ebx):
      MCA overflow recovery support = false
      SUCCOR support                = false
      HWA: hardware assert support  = false
      scalable MCA support          = false
   Advanced Power Management Features (0x80000007/ecx):
      CmpUnitPwrSampleTimeRatio = 0x0 (0)
   Advanced Power Management Features (0x80000007/edx):
      TS: temperature sensing diode           = true
      FID: frequency ID control               = false
      VID: voltage ID control                 = false
      TTP: thermal trip                       = true
      TM: thermal monitor                     = true
      STC: software thermal control           = true
      100 MHz multiplier control              = true
      hardware P-State control                = true
      TscInvariant                            = true
      CPB: core performance boost             = false
      read-only effective frequency interface = false
      processor feedback interface            = false
      APM power reporting                     = false
      connected standby                       = false
      RAPL: running average power limit       = false
   Physical Address and Linear Address Size (0x80000008/eax):
      maximum physical address bits         = 0x30 (48)
      maximum linear (virtual) address bits = 0x30 (48)
      maximum guest physical address bits   = 0x0 (0)
   Extended Feature Extensions ID (0x80000008/ebx):
      CLZERO instruction                 = false
      instructions retired count support = false
      always save/restore error pointers = false
   Logical CPU cores (0x80000008/ecx):
      number of CPU cores - 1 = 0x3 (3)
      ApicIdCoreIdSize        = 0x2 (2)
   SVM Secure Virtual Machine (0x8000000a/eax):
      SvmRev: SVM revision = 0x1 (1)
   SVM Secure Virtual Machine (0x8000000a/edx):
      nested paging                          = true
      LBR virtualization                     = true
      SVM lock                               = true
      NRIP save                              = true
      MSR based TSC rate control             = false
      VMCB clean bits support                = false
      flush by ASID                          = false
      decode assists                         = false
      SSSE3/SSE5 opcode set disable          = false
      pause intercept filter                 = false
      pause filter threshold                 = false
      AVIC: AMD virtual interrupt controller = false
      virtualized VMLOAD/VMSAVE              = false
      virtualized GIF                        = false
   NASID: number of address space identifiers = 0x40 (64):
   L1 TLB information: 1G pages (0x80000019/eax):
      data associativity        = full (15)
   L2 TLB information: 1G pages (0x80000019/ebx):
      data # entries            = 0x10 (16)
      data associativity        = 8-way (6)
   SVM Secure Virtual Machine (0x8000001a/eax):
      128-bit SSE executed full-width = true
      MOVU* better than MOVL*/MOVH*   = true
      256-bit SSE executed full-width = false
   Instruction Based Sampling Identifiers (0x8000001b/eax):
      IBS feature flags valid                  = true
      IBS fetch sampling                       = true
      IBS execution sampling                   = true
      read write of op counter                 = true
      op counting mode                         = true
      branch target address reporting          = false
      IbsOpCurCnt and IbsOpMaxCnt extend 7     = false
      invalid RIP indication support           = false
      fused branch micro-op indication support = false
      IBS fetch control extended MSR support   = false
      IBS op data 4 MSR support                = false
   (instruction supported synth):
      CMPXCHG8B                = true
      conditional move/compare = true
      PREFETCH/PREFETCHW       = true
   (multi-processing synth): multi-core (c=4)
   (multi-processing method): AMD
   (APIC widths synth): CORE_width=2 SMT_width=0
   (APIC synth): PKG_ID=0 CORE_ID=0 SMT_ID=0
   (synth) = AMD Phenom II X4 (Deneb RB-C3) [K10], 45nm 965 Processor
CPU 1:
      model           = 0x4 (4)
      process local APIC physical ID = 0x1 (1)
      cpu count                      = 0x4 (4)
      APIC on chip                           = true
      IA64                                   = false
   MONITOR/MWAIT (5):
      model             = 0x4 (4)
      APIC on chip                          = true
      RDTSCP                                = true
      str1         = 0x3 (3)
      str2         = 0x6 (6)
      PG           = 0x0 (0)
      PkgType      = 0x1 (1)
      CMP Legacy                             = true
      AltMovCr8                              = true
      XOP support                            = false
      TBM support                            = false
      TscInvariant                            = true
      SVM lock                               = true
      NRIP save                              = true
      CMPXCHG8B                = true
   (APIC synth): PKG_ID=0 CORE_ID=1 SMT_ID=0
CPU 2:
      model           = 0x4 (4)
      process local APIC physical ID = 0x2 (2)
      cpu count                      = 0x4 (4)
      APIC on chip                           = true
      IA64                                   = false
   MONITOR/MWAIT (5):
      model             = 0x4 (4)
      APIC on chip                          = true
      RDTSCP                                = true
      str1         = 0x3 (3)
      str2         = 0x6 (6)
      PG           = 0x0 (0)
      PkgType      = 0x1 (1)
      CMP Legacy                             = true
      AltMovCr8                              = true
      XOP support                            = false
      TBM support                            = false
      TscInvariant                            = true
      SVM lock                               = true
      NRIP save                              = true
      CMPXCHG8B                = true
   (APIC synth): PKG_ID=0 CORE_ID=2 SMT_ID=0
CPU 3:
      model           = 0x4 (4)
      process local APIC physical ID = 0x3 (3)
      cpu count                      = 0x4 (4)
      APIC on chip                           = true
      IA64                                   = false
   MONITOR/MWAIT (5):
      model             = 0x4 (4)
      APIC on chip                          = true
      RDTSCP                                = true
      str1         = 0x3 (3)
      str2         = 0x6 (6)
      PG           = 0x0 (0)
      PkgType      = 0x1 (1)
      CMP Legacy                             = true
      AltMovCr8                              = true
      XOP support                            = false
      TBM support                            = false
      TscInvariant                            = true
      SVM lock                               = true
      NRIP save                              = true
      CMPXCHG8B                = true
   (APIC synth): PKG_ID=0 CORE_ID=3 SMT_ID=0
